Parking Brake
Old Mar 4, 2020 | 05:50 PM
mrgeemoney's Avatar
2016 GLE 450 AMG
Angry Parking Brake
I have a 2013 Mercedes ML350 and I’m getting the message “Parking Brake See Operator Manual” and the yellow parking brake light stays on also. I stopped using my parking brake because the left rear brake was getting stuck and won’t disengage so I would have to play with the parking brake switch to get it to unlock.
I replaced the parking Brake switch but the lights still stay on. I did a computer diagnostic and got 2 faults with the Parking Brake.
1. The position of component Electric Parking Brake is Implausible
2. The left brake caliper is faulty. An open circuit exists.
Can someone tell me if this could be a faulty sensor on the left rear wheel or something else?
Old Mar 5, 2020 | 03:37 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the wrong forum.
https://mbworld.org/forums/m-class-w166-149/
The problem is not your caliper. It is with the parking brake shoes. One or both of them have detached.
Old Mar 5, 2020 | 07:27 AM
mrgeemoney's Avatar
2016 GLE 450 AMG
Thank you, I will have a look this weekend and let you know!
Old Mar 5, 2020 | 09:39 AM
Here are the procedures, especially the last PDF.
After you remove the caliper, you must adjust the parking brake shoes so they contract. Turn the adjusting wheel in one way and spin the rotor and see if it gets tighter. If it does then spin the wheel in the opposite direction.
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 5, 2020 | 02:06 PM
mrgeemoney's Avatar
2016 GLE 450 AMG
Thanks!!!!!!!
Old Mar 11, 2020 | 08:01 PM
mrgeemoney's Avatar
2016 GLE 450 AMG
Took off the caliper this past weekend and saw I don't have parking brake shoes! I think I might have to buy a new caliper.
Old Mar 12, 2020 | 04:48 AM
All cars have parking brake shoes. You have to remove the rotor to see them.
Old Mar 13, 2020 | 04:28 AM
mrgeemoney's Avatar
2016 GLE 450 AMG
I ordered a left rear parking brake actuator, lets hope that is it, Thanks!!!!
Old Mar 13, 2020 | 07:26 AM
Why did you order shoes when you did not remove the rotor to see if they were damaged?
Old Jun 23, 2020 | 08:58 PM
mrgeemoney's Avatar
2016 GLE 450 AMG
Finally got the left rear parking brake actuator and installed it, that was the problem! No more “Parking Brake See Operator Manual” message!!!
