M-156 torque specs help needed
Old Mar 17, 2020 | 12:29 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
I am replacing right side intake camshaft and all 8 followers.
1 Could someone please give me the specs for bolts on valve cover bolt torque and what order to torque them up.
2 Camshaft bracket bolts torque and order they have to be tightened As well as the double bracket that holds intake and exhaust camshaft.
4 Timing cover bolt torque specs.
3 Camshaft adjuster bolt torque specs
Thank you!
Old Mar 17, 2020 | 02:35 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
This should help.
Ignore these PDFs as they are the wrong procedures
Old Mar 17, 2020 | 03:48 PM
IgorE350's Avatar
Originally Posted by Maj. Dundee
This should help.
This is a different engine specs that you attached are for M272 M273 I need specs to M156 engine that sits in 08 Mercedes ML63AMG
Old Mar 17, 2020 | 06:41 PM
Here it is.
File Type: pdf
File Type: pdf
Old Mar 17, 2020 | 09:24 PM
IgorE350's Avatar
Here it is.
That is awesome!! Thank you!
What about that camshaft adjuster bolt torque? could you please give me that as well??? Thank you soo much for your help i really appreciate it.
Old Mar 18, 2020 | 06:41 AM
Here it is.
Old Mar 19, 2020 | 10:57 AM
IgorE350's Avatar
Here it is.
Finishing the job today. Thank you so much for the info,you helped me a lot
Old Mar 19, 2020 | 08:02 PM
IgorE350's Avatar
Finished today, everything seems to be fine. No ticking noise. Only one lobe was bad and one follower.Thank you Mr Dundee!!!
