Xenon light problem help
That might be the reason that it works on the BMW but not on yours.
I did open the headlight and fixed the wiring and one of the motors had to fixed broken wire. I will double check and update. Thank you.
9088 a right headlamp component is defective.
that is what confusing I can not seem to find what that code is other than what the scanner is telling me.
When you replaced the ballast did you remove the front bumper?
You originally had a problem with the right side and now you are getting codes for both sides
Did you thoroughly read the first PDF I supplied you with, especially the highlighted areas?
Are you referring to this module?
I cannot solve your problem.
Pretty sure it has active curve illumination? This is for VIN 4JGBB86E28A361381
The rest of the story...
I was previously receiving the ABS / ESP unavailable / inoperative warnings. Codes indicated a bad steering angle sensor, a bad right rear speed sensor, and a multitude of CAN message failures. Real time data showed valid speed from three of the four wheels but not the right rear. So I replaced the right rear speed sensor, and it was then reporting wheel speed consistent with the others. I reset the ABS / ESP faults and that has been clear. Curiously, the steering angle sensor shows valid data, but the rotational speed entry never goes to zero even when the wheel isn't being turned. But it no longer reports as a steering angle sensor error, so I'm going to disregard. It's been about a week and a couple hundred miles of driving.
Before and after the speed sensor replacement, I was receiving these as well...but they seem to have cleared (except for 9023) and not returned.
XALWA-L Xenon Headlamp Left
9062 No CAN message 'Steering Angle' from control module SCM [MRM] or message is faulty
9065 No CAN message 'Yaw Rate' from control module ESP or message is faulty
XALWA-R Xenon Headlamp Right
9022 Component E2m2 (Right dynamic curve illumination motor) has excess temperature or undervoltage
9023 The sensor for curve illumination is defective or blocked
9062 No CAN message was received from control unit SCM [MRM]
9065 No CAN message was received from control unit ESP
So currently, the only code for a full scan is the right side "9023 The sensor for curve illumination is defective or blocked". I've been using an Innova 5610. Thank you.
EDIT--it was approved. Apologies for the back-to-back-to-back postings. Didn't mean to spam the board.
