Ml 350 airmatic compressor starts, engine stops
Old May 23, 2020 | 05:01 AM
Gábor Varga's Avatar
ml 164 350, w124 300D
Regards (sorry for the language errors).
There is a problem with the 350 ml if the compressor starts and the engine stops.
the previous owner replaces the relays.
in the engine compartment on a switchboard
Yellow A 002542 14 19
per compressor 002 542 23 19
Then a big spark and an engine stopped,
if I did not allow a relay to be retracted, a motor will turn on, but a motor will stop when a relay and a compressor operate.
can anyone find someone with such a problem?
there are no error codes.
Which peripheral do you think is damaged?
Thanks in advance for the help
Old May 23, 2020 | 08:03 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Post your full vin#.
Old May 23, 2020 | 09:09 AM
WDC1641861A222471
Old May 23, 2020 | 11:14 AM
Please UPDATE YOUR PROFILE to include the year 2007 ML350 4matic and where you live. Erase W124.
Old May 23, 2020 | 11:17 AM
There are no relays for air conditioning.
Please take a photo of the relays that you are referring to.
Old May 23, 2020 | 12:17 PM
yellow to green
A to G relay
Old May 23, 2020 | 12:26 PM
I still thought there could be no problem with the generatorI still thought there could be no problem with the generator
charging 13.6 v.If I connect all the consumers it will drop 13.1v 11.9v
the controls units may turn offcharging 13.6 v.If I connect all the consumers it will drop 13.1v 11.9v
Old May 23, 2020 | 12:31 PM
Which relay is causing the problem?
Old May 23, 2020 | 01:35 PM
he put the yellow in its green place
the relays themselves work
in the picture, "A" was inserted in place of "G"
And it is a phenomenon that the compressor starts. the engine stops. I know it's hard to diagnose.
Old May 23, 2020 | 02:09 PM
Relay A is for the wiper level and G is for the air suspension.
You will have to remove that fuse box and see if any wires are melted to each other.
Old May 23, 2020 | 02:57 PM
Thanks, I'll check the wires tomorrow
