Help with 2011 ML350 Bluetec... codes
Old 09-10-2020 | 12:51 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Originally Posted by frederickcarney
Actually I don't have a sensor code. I have a 111500 code that the DPF didn't regenerate. Why it didn't is the question. I also have a 5025 code for CAN communication but this could be related to front speed sensors needing some maintenance (cleaning, adjusting?). Or -- could it code be related to one of the exhaust sensors? Yes, It would seem that a sensible first step would be to replace the DPS, being only $25. Thanks
Fred, are you using the correct motor oil for your truck? If it's yes, then do another oil change. If it's NO. then you are burning oil.
Old 09-10-2020 | 02:40 PM
frederickcarney's Avatar
2011 ML350 Bluetec, 4JGBB2FB6BA733038
Maj. Dundee, thanks for the reply. Yes, I thought I was using a 229.51 oil until just now when I just checked the Mercedes chart for approved oils. I typically use Pentosin 5w40. The 5w30 is approved but the 5w40 is not. I order from FCP Euro and they confirm it is an approved oil. I'll change to the 5w30 or use the Mobil1 5w30 (which I typically use in the winter). Thanks
Old 09-10-2020 | 03:30 PM
Pentosin is not on the list.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Old 09-10-2020 | 04:27 PM
I believe I should be looking at 229.51, not 229.5, correct?
Old 09-11-2020 | 07:17 AM
They still are not on the list.
https://bevo.mercedes-benz.com/bevol...229.51_en.html
frederickcarney (09-11-2020)
Old 12-01-2021 | 09:50 AM
sabb's Avatar
E500
Code 106100 - OM642 Blutec R350 w251
Same issue here with the only code 106100. Car 57k miles with no prior emission problems since 42k miles purchased. Oil changes around 5k miles with MB oil.
Anyone who was able to fix code 106100 that can provide some guidance would be greatly appreciate it.
Quick Reply: Help with 2011 ML350 Bluetec... codes
