Steering Angle Sensor Repair - Stripped Screw
Any ideas on how can I loosen that screw would be welcome.
You would need a 1/2 inch breaker bar with the appropriate socket to remove that screw/bolt.
If you stripped that hole, you have a big problem.
By th way I tried also with a bit bigger Torx and no luck..
I think the only remedy you have is to drill out the head of that screw but it must be done with the negative battery cable disconnected.
This of course is only a suggestion and the decision is yours to make.
do we have any pictures on how the screw looks like? Ideally I would like to see the dimensions of its head to understand how much I should drill if I opt to follow that path. Of course the battery will be disconnected if I do it
You must start with a drill bit a little larger of the damaged screw hole. Drill a little, then use the next larger drill bit and so on and so on, until the head disappears, then you will be able to pull the Air Bag out.
The only drawback is those screw/bolts are not available from M/B. You will have to try junk yards for that screw.
Here is a photo of where the bolts go to the Air Bag.
Since the bolt hole is rounded, try using Hex bit set.
Is there anything else in there, that I may break while drilling (assuming that I drill only on the bolt head)?
By the way, the other screw that I was able to un-tie, since it stays in place, I can't really look at it and understand how big is the head. I tried using my phone camera but it is not that clear..
I guess I will have to look into a junkyard to find one, and to also get a replacement.
