Rear springs assembly W164
Old Sep 6, 2020 | 12:57 PM
Taiter's Avatar
2008 W164, 2009;GMC Serra
Hi could anyone tell me the sequence of the rear spring assembly on a W164 as it is mounted.
Old Sep 6, 2020 | 01:15 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Coil or air springs?
Old Sep 7, 2020 | 08:12 AM
Taiter's Avatar
I am sorry, coil
Old Sep 7, 2020 | 09:45 AM
Are you asking how to remove the coil spring while the whole strut is on the car? If so, it is impossible.
Why are you replacing the springs?
Old Sep 7, 2020 | 03:17 PM
Taiter's Avatar
The springs broke Due to the heavy use of winter salt on the roads here in Ontario I was asking if the Plastic parts that go on the spring is correct.
Old Sep 8, 2020 | 06:58 AM
Here is the parts list on a general basis. Parts 110 & 170 will need full vin#.
Old Sep 22, 2020 | 05:33 PM
Taiter's Avatar
Could anyone tell me which way does the item 125 mount onto item 120
Old Sep 22, 2020 | 08:08 PM
It's quite obvious from the diagram.
Old Sep 23, 2020 | 05:34 AM
Taiter's Avatar
I was wondering if you had an other drawing the item 125 has tabs.
Old Sep 23, 2020 | 01:55 PM
No I do not.
