y31/1 (egr vacuum transducer) testing
Old Dec 11, 2020 | 11:40 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi there,
2006 ML500
I have a P0400 code. I cleared the code, no engine light on now, but the code shows when I scan on the merc software of the reader.
It has an option of active testing "y31/1 (egr vacuum transducer)". When the test is run with all the prerequisites, it just makes the idling a bit rough, as it warns prior to test; and that's about it. My question is when you do the test, should the engine stall or run normally. Also why MIL shows no fault. I have driven the car quite a bit since I cleared it. Thanks in advance.
Old Dec 11, 2020 | 12:58 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Just wait and see if the code returns. If it does, the problem might be the 14 yr. old vacuum hose to the Transducer being cracked.
Old Dec 11, 2020 | 02:26 PM
anavabi's Avatar
Thanks Major.
The code does exist on the module scan but not on MIL.
Are there 2 of them on this engine? Removal instructions is much appreciated. Thanks
Old Dec 12, 2020 | 04:06 AM
Originally Posted by anavabi
Thanks Major.
No, on a 500 there is only one. If the CEL is not lit, you do not have a problem.
Removing it is very difficult in that it is on the rear of the eng. and you will need a mirror. Don't cry if you damage it.
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 12, 2020 | 07:57 AM
anavabi's Avatar
Thanks Major for your help. It just bothers me why I get the code when I do the scan all but no MIL.
Old Dec 12, 2020 | 09:43 AM
Does the CEL light come on when you turn the key to pos. #2?
Old Dec 12, 2020 | 10:37 AM
anavabi's Avatar
yes
Old Dec 12, 2020 | 10:50 AM
yes
Then you have nothing to worry about.
Old Dec 12, 2020 | 11:51 AM
anavabi's Avatar
Thank you
