WSS Calibration
Just a little history on how I got here.
A few weeks ago I replaced the battery. I think I must have caused a problem with the WSS then. After replacing the battery I got the SRS fault. I checked with my scanner and found a fault code 9A07 B48/14 right rear sensor has an open circuit in the wiring. I thought I might have cut a wire moving the seat up and forward to take out the battery. I looked and looked but could not see any problem. I decided to take it to the MB dealership. They did a scan and told me that they would have to replace the the seat base frame. Cost $3400.00. I told them they should look for a open circuit to the right rear sensor B48/14. And if needed replace the sensor and re-calibrate the WSS. They told me that, that is not what MB recommends. I told them that they where nuts. That they should be at least able to replace the sensor and re-calibrate the WSS. He asked me give him a few minutes he would check with their parts manager. Later he told me that they could do that for $1400.00 with no guarantee that it would work. At that point I paid for my scan and told them I could not trust anything they said.
the next day I decided to look for an open circuit to B48/14. I unbolted the seat and tried pushing on all connections and looked for any wires that might have been damaged. No luck. I put the seat back and did another scan. I no longer have the open circuit error codes. Now just the code saying the WSS is incorrectly adjusted.
So I think I might need to find someone trustworthy with the right tools and knowledge to do the job.
Did you remove the front seat to replace the battery?
