Lurching on approach
Old Mar 1, 2021 | 03:09 PM
2008ml550_0104's Avatar
08' ML550, ML 63, E55, and 2019 S63, 19’ Porsche 991 911 Speedster
The scenario:
on a normal day it happens maybe once or twice. Depending on driving habits, I know mine are not always the best.
scenario 1. I will be in a parking lot usually and I will begin to approach an open parking space. Slowing down and transmission in gear 2, or 1 (if possible to get in that gear at approach) and the rpms will drop from 1500 to about 1000 and the car will lurch without any input from me. I’ll call the lurch of “call insurance company, needs new bumper”. It’s aggressive and if your foot is not on brake or near it, your hitting who’s in front of you.
scenario 2. Same situation above, only that this time at a much fast speed approaching light, foot applied to brake, and downshifting again into 2nd and the rpms will do same thing. They drop below 1000rpm and it’s like the computer or throttle body or air intake is trying to catch back up to some determined point and it overcompensates for what it’s calling for and does the lurching thing. Is this related to more than a transmission/adaptive reset issue, can it be prevented and stopped by a tune or what’s happening.
Old Mar 2, 2021 | 03:36 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
I had the same problem last year and a trans. oil & filter change did the trick.
Understand that to do this, special equipment is necessary, which you probably already know.
Old Mar 2, 2021 | 11:56 AM
Yea
Old Mar 2, 2021 | 01:58 PM
it’s alright I call you Mick? Alrighty. It’s a simple fluid change and no there aren’t really any special tools. I must have missed that part. Here’s what I will be doing...Idk about the way you do it, but you hook up to the drain plug and there is a green or white tube inside that sticks up and inch or 2 and u pump 5 liters in, begin to shift, and shift it couple times more then pump some more in usually 6 to 7 liters then u have to run the car shift it a bunch of times untill it reaches about 110 degrees then u open the drain and let it spill out untill it's a dribble then cap it - have to have the scanner hooked up to see the transmission temp takes 45 min to an hour to check the fluid level
