B12 refrigerant pressure sensor - where is it?
Old Apr 17, 2021 | 03:09 PM
Lee Stone's Avatar
ML320 CDi W164
Hi folks,
I have a 2006 ML320 CDi W164, right hand drive (UK). I have a problem with my radiator fan coming on about 5 seconds after start up and remaining on until switching off the engine. On checking with my iCarsoft I am getting the following, B12 open circuit. Where do i locate the B12 Refrigerant pressure sensor and can it be repaired DIY or is it a mechanic job?
Thanks in advance for any support
B12 sensor
Old Apr 18, 2021 | 02:48 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Old Apr 18, 2021 | 12:55 PM
Lee Stone's Avatar
ML320 CDi W164
Sorted!!! Cable connector off...cleaned and firmly fastened back on, DTC cleared, main fan no longer coming on.....hoorah!
Old Apr 18, 2021 | 01:19 PM
Thank you so much.
Old Jul 2, 2022 | 11:45 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi Major,
I have problem with my ML500 air con fan blowing warmer air at random while driving. It gets better when idling; otherwise decent cool air is blown. Would replacing this sensor rectify the issue?
Thanks,
Old Jul 4, 2022 | 05:39 AM
Did you ever consider checking for codes?
Old Jul 4, 2022 | 07:26 AM
anavabi's Avatar
Yes. With a scanner equipped with Mercedes software that checks for AC as a feature. Got all clear message.
My guess is perhaps one of the sensors is on the way out. Besides, the cool air is not really a chilling cold air as it used to be, but it's ok.
Old Jul 4, 2022 | 01:41 PM
Then I would say that your refrigerant is not up to par caused by a slow leak somewhere in the system.
Old Jul 4, 2022 | 04:28 PM
anavabi's Avatar
If by not up to par, you mean of low pressure, I keep checking the refrigerant pressure. The pressure has been dead on every time I check with a gauge. Not a slightest drop.
Would this intermittent cold/warm air not the result of a sensor going bad?
Old Jul 5, 2022 | 06:31 AM
Spend $70 and get a real scanner.
Amazon Amazon
Old Aug 8, 2022 | 01:56 PM
anavabi's Avatar
Finally got 3 codes using a new scanner, namely 9601, 9803, & 9804, as per attached. Do these mean I have to pull out the dashboard?
File Type: pdf
Old Aug 10, 2022 | 07:50 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
LUCKY 😊
You get to play again...
stored faults... zero current fault 👍
If i had to guess, I'd say someone played with all the buttons too long. Now you know this car is watching your every move
Clear these codes then scan again after couple drive cycles.
Old Aug 11, 2022 | 08:06 AM
anavabi's Avatar
Yes, because of the issue I had, I did play around with the buttons. I did clear the codes and now I have no codes after a couple of cycles. But the original issue still exist.
I'll keep an eye and report back. Thanks
Old Aug 11, 2022 | 12:42 PM
LIVE DATA
ok, now you know there is nothing your AAC Module is complaining about: no fault!
It's up to you to analyze the data it is using....
  • pressure data
  • temperatures data
Q: Does your A/C compressor uses a clutch or always spins non-stop ?
Old Aug 11, 2022 | 01:21 PM
anavabi's Avatar
  • pressure data
  • temperatures data
Always on
Old Aug 11, 2022 | 01:27 PM
Always on
these type of compressors are activated by a solenoid that gets lazy... bang it, test it or replace it
Old Aug 11, 2022 | 02:05 PM
anavabi's Avatar
Great, thanks a lot. Would you please share the part number for the solenoid. Thanks.
Old Aug 11, 2022 | 02:11 PM
PWM solenoid
I would if I had it. Find this item attached to the compressor body.
Old Aug 11, 2022 | 02:13 PM
anavabi's Avatar
