Front Control Arm, Sway Bar Bush Replacement
Old May 31, 2021 | 08:45 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Looking for assistance please. I need to change the bushes on the front upper and lower control arms as well as sway bar bushes and trailing links, and am seeking instructions as well as torque settings for all fasteners. Any advice appreciated.
2010 ML550 with Airmatic
Many thanks
Old Jun 1, 2021 | 09:52 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here are the procedures and understand that a hydraulic press is needed to remove and install the bushings.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 1, 2021 | 07:17 PM
BlackML550's Avatar
Many thanks Major. That is very helpful. I have a press. I wouldn't be attempting this without one.
Old Sep 6, 2022 | 05:27 PM
efzauner's Avatar
2005 C240 2011 R350
hello
Did you manage to replace them? What bushing tool did you use?
thanks
Old Sep 6, 2022 | 11:50 PM
BlackML550's Avatar
I used a generic bush removal tool as well as a press. However for one of the lower control arm bushes, it needed to be cut out. That was not easy and I can see why people simply buy the whole component with new bushes already installed.
Old Sep 7, 2022 | 06:12 AM
efzauner's Avatar
2005 C240 2011 R350
Thanks , there are so many different sets of tools available. do you have a model?
Why did you have to cut it out? Was it corroded in place?
Old Sep 7, 2022 | 07:06 AM
BlackML550's Avatar
No it was a generic tool set. We had to cut it out because it just wouldnt come out. Thats how hard they are pressed in. No corrosion to speak of.
