Sinking Brake Peddle
With the new shock absorber I also replaced the "sway bars " ... now the car handles like a dream !!!! ..that's the good news !
Immediately after replacing the front shocks the brake peddle got soft! You can push it down to the floor ,slowly but you can.
Well best guess was Master brake cylinder got faulty for some reason
Contacted MB about the cost of the master brake cylinder , living in Australia , they quoted $850 ....well you can get the parts by far cheaper in the US or Europe which I did ( the exact part / partnumber) paid approx $200
: replaced the cylinder with new ATE cylinder, pressure bleed it ..... same problem
Next best guess was calipers and brake hoses (front left and right, sourced overseas ) .... problem still there
I searched the forum re similar issues and found a few threads which basically pointed to ABS bleeding
I have a Icar scanner which unfortunately does not assist with the bleeding of the ABS module. That is the only thing I can't do
Is there any other way to bleed the ABS module ? first question
..and what else may I have overlooked ? It is rather frustrating ! In addition when you buy overseas it can take up to 8 weeks to get the parts. Still worthwhile looking at what MB charges for the exact same parts!
The brake performance is still good but it is not the way is was and should be .
Any ideas , past experience , how to fix the problem !
Thanks and best regards from Australia
Also, does your ML fall in the range of the recall for brake systems that we have here in the US?
https://www.consumerreports.org/car-...s-a6346785543/
...well checked it out > Yes the function is there .
I tested the brake with esp on/off / hillstart on/off ... still got the sinking pedal .
When you stop your car come to an halt, what happens then ? Do you still can push the pedal to the floor ?
As far a braking my car is concerned, it engages very quickly and effectively.
...but the sinking pedal was not there before !!!!
following your ideas then maybe there is a sensor not working , just don't know.
I thought that function may not be working properly and that was causing your problem. Ive attached photos from the handbook.
... the thing is , that the problem started after replacing the front right shock absorber.
cheers
I recently got the local yearly road worthy check . For that I made the mechanic aware of the problem . The answer was : he has seen a few cars with the problem but it does not effect the braking capability.
Further , 2 weeks ago I got my recall check . All ok !.. I made the "MB" mechanic aware of the problem , he did a test drive , sort off acknowledged the problem but dismissed it as a problem coming to the same conclusion as the above mechanic.
As I mentioned in the very beginning of the thread, the problem occurred/started after replacing the front right shock.
I have the rear brake hoses on order and when replacing them I will replace the Master brake cylinder again !! and of course bleed the system.
As to the noise when pushing the pedal ... that needs to be further investigated. I live in country Australia/NSW, so specialist workshops are not readily available . There is a brake specialist some 200 miles away.
I let you know how I go ! Please keep me posted too
Otto
