2008 ML350 Driver Side Mirror Jammed
Old Dec 14, 2021 | 08:32 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi Everyone,
This car has been standing still for some time now. I've been doing some odd maintenance on it like changing oil, running the engine for a while to keep the battery alive, etc. But I just found out that driver side mirror is now jammed and doesn't move in any direction at all. There's a buzz noise for every direction but no movement. First there was a slight movement and I tried some heat and gentle push with my hand; but that only made it worse such that it stopped all the movements. Any thoughts ang guidance will be much appreciated. Thanks.
Old Dec 14, 2021 | 05:13 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Is the mirror folded in towards the window?
Old Dec 14, 2021 | 06:33 PM
anavabi's Avatar
Mirrors are fixed and not foldable. Only the glass part inside the housing rotates in 4 directions.
Old Dec 15, 2021 | 03:50 AM
You didn't answer the question. Is the mirror folded in towards the door window?
Old Dec 15, 2021 | 09:39 AM
anavabi's Avatar
Sorry, it is folded away from the window, and down. Both max extent.
Old Dec 15, 2021 | 12:32 PM
I have no idea what you mean by and down. Take a photo and post it.
Old Dec 15, 2021 | 02:42 PM
anavabi's Avatar
Here are some photos
Old Dec 16, 2021 | 07:24 AM
What is that object, red arrow? Never seen that before.
Does the entire mirror fold in to the door glass?
Old Dec 16, 2021 | 08:48 AM
anavabi's Avatar
1- "What is that object, red arrow? Never seen that before."
That is an after market blind spot mirror. I attached that years ago, and the mirror has been working fine with it for years.
2- "Does the entire mirror fold in to the door glass?"
No, the entire mirror has folded away from the door, as seen on the picture and is stuck there. Not sure if that answered your question.
Old Dec 16, 2021 | 10:04 AM
With the key out of the ign., force the mirror towards the door window until there is an opening and liberally spray WD40 on the pivot point. Then manually work the mirror back and forth and see if it worked.
File Type: pdf
Old Dec 16, 2021 | 12:13 PM
anavabi's Avatar
It did the trick. Thanks a lot Major.
Old Dec 16, 2021 | 12:43 PM
You must do this to both mirrors every 6 months.
Old Dec 16, 2021 | 01:42 PM
anavabi's Avatar
Yes I did the same with my other ML. Thanks again.
