ML320 Rear Brake Lines
Old Jan 15, 2022 | 01:39 PM
mickydodo's Avatar
ML 320 2008
I am wondering has anyone replaced the steel brake lines on an ML. I am assessing what needs to be done to replace the existing steel rear brake lines on a 2008 ML320. It seems the route of the line goes above the fuel tank and looks inaccessible without dropping the fuel tank which requires the removal of rear drive shaft.
Would it be acceptable to re-route the brake line and avoid having to drop the fuel tank? Any other advice would be much appreciated.
Old Jan 16, 2022 | 04:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Replacing brake lines is not an easy task and must be done on a lift. Special tools are needed and if bleeding is not done correctly, you will not be able to move the car.
Here are You tube videos .
https://www.youtube.com/results?sear...ve+brake+lines
