No Acceleration
Old May 2, 2022 | 06:08 PM
Joy1's Avatar
2008 ML320 CDI
No Acceleration
Hello,
I'm new here. I wanted to know if anyone can help me figure out my truck issue.
No check engine light, yet my truck will not accelerate when pressing the gas pedal. I can hear the engine rev and truck will not move.
no codes, check codes with MB II icarsoft tool. only message on dash is brake wear.
Old May 3, 2022 | 12:19 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Did the acceleration problem occur at the same time the message on dash is brake wear came on? If so, this is a safety measure telling you to replace the warn pads and you will get your acceleration back.
Old May 3, 2022 | 09:34 AM
Joy1's Avatar
2008 ML320 CDI
Hello,
Maj. Dundee
The light was on for a while, the truck turned off while driving. Pulled over and it started back up yet couldn't pull off, no acceleration.
Towed home now, no check engine light and no codes. I will take a look at the brakes.
Old May 3, 2022 | 10:27 AM
Originally Posted by Joy1
Hello,
Maj. Dundee
You really didn't answer my question, but there has to be a code stored for this problem.
Do you have a scanner reader? If you do, check for codes in all modules.
Old May 4, 2022 | 03:32 AM
grkmspr's Avatar
ML350 - 2007 164.186
Maybe Differential is broken.? Focus on it. I had the same problem before.
Old May 19, 2022 | 06:23 AM
ahmedroyce's Avatar
e30 2000
Nox Vidmate VLC
Old May 27, 2022 | 01:11 AM
grkmspr's Avatar
Hello,
What is the result?
Old May 25, 2023 | 07:13 PM
Joy1's Avatar
2008 ML320 CDI
Hello, everyone I do apologize I had to take care of a family member, and put the truck aside.
SO far the truck is still sitting in the same position, haven't found what could be the issue.
I did find that the brake light as do to the brake wear sensor was missing the metal insert, it wasn't able to read. I replaced the sensor and the warning light went out.
Was under the truck while my daughter pressed the gas pedal and the drive shaft from the front diff to the torque converter, turned and quickly turned back, did not complete a full 360.
Old May 25, 2023 | 08:00 PM
Joy1's Avatar
2008 ML320 CDI
I haven't found the fault, yet. can you tell me what your truck symptoms where?
Old May 26, 2023 | 01:01 AM
grkmspr's Avatar
Hello,
In my vehicle, the vehicle is rolling over, but not moving.
the part of the differential I showed below was locked/broken so Cardan Shaft didn't turn it also locked. before this part broke, car kicks when slowing down.
red part is broken.
Old Jun 26, 2023 | 08:58 PM
Joy1's Avatar
2008 ML320 CDI
Do any of you know what these wires go to?
