2010 ml350 4matic "Drive to workshop" fault code
After I first put part back on the cable wasn't on all the way. I got fault code " No communication with TCM. jacked it up again and made sure cable on. Ran icarsoft E660 diagnosed not getting that fault now. Car would start but not go in gear. After 4 or 5 times taking key out and restarting engine I did got " CAN communication loss" fault. Does this mean I have a short circuit in the GATEWAY CONTROL MODULE Unit? ,causing "Drive to shop " when car door is opened, and the intermittent fault, "CAN communication loss"?
UPDATE:
Also got fault code " Teminal 30 low voltage " or similar message.
UPDATE:
I did take the battery out and fully charged it. Explained fault code "Terminal 30 low voltage. Alternator reading 14.3 volts. Let it set for overnight now battery completely dead again. What could be draining battery? I know its related to "DRIVE TO WORKSHOP " as soon as car door opened. Apparently this stays on and draining battery. Just need help in validation of this conclusion.
I have already removed original DSM, shipped it and replacement donor to ebay cloning serviceserIt was programmed a mailed back.. I reinstalled on Ml350. Thats when the it gave fault. Drive to workshop when ever door is opened.. No key in ignition.
I need to relearn the shift positions with Xentry? This step I have not done. New part is still on car. I'll see if I can get a mobile mercedes tech using xentry in Houston TX.
You must R&I the ISM/DSM again and follow instructions to a "T" especially step #14 in the first PDF. If you used short cuts in R&I, you have problems.
Okay,
I ordered the 722 assembly tool 🔧 for turn transmission gear on its way. Question: to put in the P position can I just turn it counterclockwise as the instructions say. Does the key need to be in the ignition, turned to position 1 or 2. Or will it let me turn idle sitting? I'm taking you advice putting original back on and found a mobile tech to run xentry on it afterwards. Just want clarification on right way to turn transmission ⚙ gear into the P position for original ISM.
Okay,
Understand that I have just supplied the procedures and I have not had this problem on my vehicle.
2010 ML350 4matic W164 all Dash panel lights flash on, then into limp mode. I disconnected battery for 2 mins and able to drive home normally. This happens intermittently now. Scanned with Icarsoft E660 only 1 fault code 91B6 (CAN controller: CAN bus Off, In the case of the fault' Bus Off ' the control module is isolated from the CAN bus because of a major communication fault) . Did some CAN Network research on troubleshooting CAN H and CAN L with Gateway and suggest possible short circuit and/or short to ground of CAN H to CAN L.
To diagnose with ohm meter and hopefully locate short circuit In need of the ML350 4matic W164 wiring diagram and/or CAN network diagram. If anyone has wiring diagram I really appreciate a copy.
