iCarsoft V3.0: ESP Inoperative. Code reading?
Here's a some pictures that I have taken from the fault, can anyone give me an idea if your familiar with reading codes to tell me what is it that I am looking at? Any info would happily appreciated. Thanks
The other codes that you've shown don't seem to relate to the ESP fault. Also, a scan tool won't tell you what to change, its just there to point you in a direction. At this point, I'd clear all the codes (on a module by module basis) and then see what reappears.
iCarsoft Sucks big time for me, I purchased Foxwell NT510 elite and it actually performs more and easier to understand. It actually does the ESP "test", also I havent pinpoint it, but I actually believe its the battery, It's still OEM and havent changed since 2010. When I get that change, will let you know!
If you want a serious tool to diagnose and fix electronic problems, activate, adapt and calibrate control modules, make configuration changes, etc., the best is XENTRY from @BenzNinja. With BenzNinja, you get dealer-level (and better) support remotely and virtually from anywhere and anytime (as long as you have an internet connection).
If you want a small, compact, portable keep-in-your-vehicle, yet powerful scanner, I think the best scanner right now is the LAUNCH Creader Elite 2.0 BENZ from Amazon.
C4 Multiplexer w/ DoIP: ~$450 or less. Example ONLY https://www.obdii.shop/goods-5-C4-MB...RoCtfMQAvD_BwE
XENTRY and associated Software: ~$85 from @BenzNinja (plus club membership). (You need to confirm pricing and other benefits with BenzNinja. I would check with BenzNinja before buying anything and get his recommendations.)
Keep in mind that the MB Star Diagnostics System (i.e., XENTRY) is a dealer-level tool, which normally would cost thousands of dollars. Membership in the BenzNinja club gives you access to dealer/factory level programming, as well.
