2009 ML550, Trans drain and fill?
Old Aug 24, 2023 | 02:44 PM
alexk243's Avatar
2009 ML550
I just purchased a 2009 ML550 with 133000 miles. I have service records and it looks like up until 80000 miles it was serviced at MB dealerships. I am going through everything on it and debating a trans drain and fill. Is that suggested on a higher mileage ML550 without knowing it's full history or if it's been done before?
Old Aug 25, 2023 | 12:44 AM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
Even if it was done last at 80,000, it is time again. Do some searching to find the procedure. You need a fitting to fill the trans from the drain, a way to measure trans fluid temp and the procedure to check the fluid level.
Old Aug 25, 2023 | 04:04 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
2009 ML550s also have a torque converter drain plug where you can drain extra fluid, noting that dropping the pan only gets about 50% of the fluid out. Some W164s don't seem to have the TC drain plug, so its worth checking.
Old Aug 25, 2023 | 10:32 AM
alexk243's Avatar
2009 ML550
I was not concerned with if it wasn't done at 80000 should I still be doing it? I know there are some different thoughts on changing transmission fluid if it's never been done.
Old Aug 25, 2023 | 03:28 PM
BlackML550's Avatar
I don't think 133k is too far gone to avoid changing it. Do the pan replacement only (1/2 the fluid) and then in 20-30k more, do it again. Then you're avoiding the problem youre worried about.
Old Aug 26, 2023 | 09:17 PM
EWT's Avatar
EWT
You don't want to flush the transmission if it is high mileage with no maintenance. Draining and filling is unlikely to cause a problem.
Old Aug 27, 2023 | 04:04 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
always do the service if you have any doubts about when it's done. I've done it at 150k with zero detriment multiple times on loads of Mercedes.
I recommend this stuff if you want to improve the function of your transmission and if you'd like to support the forum
https://www.amsoil.com/p/signature-s...EA/&zo=7236674
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Aug 28, 2023 | 09:46 AM
texas008's Avatar
2007 GL450
I'd go for the 722.9 filter upgrade kit (deeper fluid pan with a updated filter), to better protect the transmission.
Mercedes Transmission Oil Pan - Genuine Mercedes 9062700501
Mercedes Transmission Overflow Plug - Genuine Mercedes 2222710097
Mercedes Transmission Filter - Genuine Mercedes 2222772800
Old Sep 18, 2023 | 10:30 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
Transmission service AMSOIL ALL THE WAY
I have used all the Amsoil products in my MB’s. The signature series tranny fluid is fantastic. I have put 50-60k miles on it and comes out looking nice and red. I have it in my 2009 ML350 and 2008 GL550, also had it in my 2006 ML500.
You can shoot tranny temp at the pan or use a good OBDII and look at tranny temp. Also there is complete how to do post… I will look for it. Link at bottom
1. New gasket, filter, bolts, fluid, ability to pump it thru the drain plug then at 113 degrees F let excess drain and put the drain plug back in.
https://mbworld.org/forums/attachmen...on-service.pdf
Old Sep 20, 2023 | 02:01 PM
alexk243's Avatar
2009 ML550
Dealership wants $650 for the transmission fluid change. I have done transmission fluid changes on all of my vehicles before, but heard this one requires a lot of special tools that add up in price. Is it worth doing myself or paying to have it done?
Old Sep 20, 2023 | 04:30 PM
vesiadog's Avatar
Once you buy the tools it is a pretty easy job. Look over the post I made with the pdf someone made. the most expensive part was the pump system which is really a sweet tool. I also maintain quite a few MB’s so it was easy for me to justify. $650 is a hefty sum.. you should be able to buy the pump around $150-200 and the rest are cheap… filter and gasket … once again I highly suggest AMSOIL signature fluids ..good luck Bill
Old Sep 23, 2023 | 11:34 AM
Gray_Panther's Avatar
ML400 - 128i - Atlas VR6
Pretty simple job, but it was time consuming for me (3-4 hours) because I work slow to make sure everything is done correctly the first time around.
The fill adapter is like $15, transfer pump $30 at any hardware store, $5 for plastic tubing and then the trans fluid change kit which can be about $150ish.
But now that I got the fluid kit from FCP, the next time I do this job the material will basically be free with their lifetime warranty program.
I did mine at 75k miles and noticed a positive change. I am at 81k now and no leaks or issues.
Edit:I probably saved $400+ and it probably would have taken the same amount of time with me driving there and back and waiting for the job to be completed at the dealer.
Old Sep 23, 2023 | 05:03 PM
vesiadog's Avatar
Fill pressure tank
I like the 2.5 gallon Mityvac 6410
Old May 11, 2025 | 04:19 PM
alexk243's Avatar
2009 ML550
Completed the trans fluid/filter change. Went with the large pan that FCP offers and did the torque converter as well. Pretty straightforward and not that difficult of a job.
Old May 11, 2025 | 04:31 PM
vesiadog's Avatar
trans fill
What brand fluid did you use? What pump did you use to fill it?
Old May 11, 2025 | 04:39 PM
alexk243's Avatar
2009 ML550
Used Fuchs ATF 4134 from FCP's kit with the larger pan and filter and some cheap pump I got on amazon, which worked fine for me. This was the pump I used: https://amzn.to/4iRajSl
