Front passenger window switch
Old Nov 5, 2023 | 11:35 AM
schmad1962's Avatar
2007 Mercedes ML350
I am looking for instructions for replacing this switch. I can't find them anywhere. Can someone help me?
Old Nov 5, 2023 | 09:48 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Might have to remove the door panel.
Check YouTube, lots of good info can be found there.
Old Nov 5, 2023 | 09:57 PM
S70Houston's Avatar
This might help, most likely identical to the ML:
Old Nov 5, 2023 | 09:59 PM
schmad1962's Avatar
2007 Mercedes ML350
Looked on youtube, could not find anything pertaining to that particular single switch, only found videos on the main window switch module.
Old Nov 5, 2023 | 10:01 PM
schmad1962's Avatar
2007 Mercedes ML350
That helped, did not see that one, thank you!
Old Nov 5, 2023 | 10:47 PM
S70Houston's Avatar
Very welcome. Hope it helps to get the job done.
Old Jul 31, 2024 | 06:29 PM
NaterDee's Avatar
2015 S63 AMG Coupe
FYI - You do not need to remove the door panel to replace either the driver or passenger side switches. A pry tool and some patience can get the job done yourself. The Bezel around the switch comes off first, then u simply pry the tabs inward on the inner switch, then around to the back to pry it out. There is a plug that pops in, then put it back. Its fairly easy to do. Finding the switches is the hard part in aftermarket sometimes. Alibaba is a decent alternative to look along with Amazon or ebay if you are trying to avoid OEM prices on the same plastic parts.
Old May 17, 2025 | 09:28 AM
gav24v's Avatar
W204 C250 Sport (AMG Package with Pano Roof)
I know that this is an old thread, but I found this post while searching myself for instructions relative to W204. Google took me here. The door panel must be removed on the W204. This is because the switch is held in place by a small torx screw, that can only be accessed after removing the door panel. Photo attached. The torx screw can be seen just above the switch harness connector.
