AIRMATIC INFO- W164 Bulletins, Service Docs, Diagrams, Settings, Remove & Install
Old Jan 21, 2024 | 09:01 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
With so much scattered information on how to diagnose and repair the W164s Airmatic system, I've compiled this thread with as many official MB documents as I can download, specific to the Airmatic system. Hopefully others will add to this as well.
The documents I have downloaded are specific to a 2009 ML550 with ADS (Code 489), so please note there may be differences between the models. I'd suggest the only difference between models might be the ADS and possibly the location of a small number of components. Please also note the dangers of getting underneath a car with a faulty airmatic system.
Included in this post and then further below are:
Overview of Airmatic System
Airmatic Components & Locations
Wiring Diagrams & Legends
Central Reservoir Replacement
Specific Notes on Airmatic
Removal & Installation of components
Fault (DTC) Codes & Measages
Please add to this if you have any other documents etc noting any specific models that the docs may be specific to.
W164 X164 W251
Old Jan 21, 2024 | 09:05 PM
BlackML550's Avatar
W164 Airmatic Reservoir Documents
More documents on Removing & Installing the Resevoir.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 21, 2024 | 09:08 PM
BlackML550's Avatar
W164 Airmatic Compressor Documents, Air spring replacement
Remove & Install Airmatic Compressor, Air Spring & Front Struts
Last edited by BlackML550; Jan 26, 2024 at 03:26 AM. Reason: Remove & Install Airmatic Compressor, F&R Air Springs & Front Struts
Old Jan 21, 2024 | 09:21 PM
BlackML550's Avatar
W164 Airmatic - Module & Valve Block Documents
Remove & Install Airmatic Control Module, R&I ADS Control Unit, R&I Valve Block
Old Jan 21, 2024 | 09:23 PM
BlackML550's Avatar
Torque Settings
Torque Settings
Old Jan 21, 2024 | 09:33 PM
Joshinator99's Avatar
ML 63 AMG
This thread is a really great idea! Thanks for taking the time to put this together. 🍻
Old Jan 21, 2024 | 09:38 PM
BlackML550's Avatar
Relay, Grounds Description & Location
Front (under hood) Airmatic Relay Location as well as location of Grounds
Old Jan 21, 2024 | 09:46 PM
BlackML550's Avatar
Airmatic Wiring Diagrams
Airmatic Wiring Diagrams and Notes
Old Jan 22, 2024 | 12:47 AM
BlackML550's Avatar
W164 Airmatic Codes & Messages
Codes & Messages Information
File Type: pdf
Old Jan 22, 2024 | 01:03 AM
BlackML550's Avatar
W164 AIRMATIC Level Adjustments
W164 Level Adjustments
Old Jan 25, 2024 | 07:39 PM
1xsculler's Avatar
GLS450
I just want it to work without the malfunction message, lol!
Looks like a lot of reading and thanks for your effort!
Old Jan 25, 2024 | 09:31 PM
ML 63 AMG
A moderator should really “sticky” this thread up top so it doesn’t get lost!
Old Jan 25, 2024 | 10:08 PM
lkchris's Avatar
'10 CL550, '12 GL550
Is there a document covering changing the compressor filter? Maybe it's painfully obvious and I confess I haven't looked at mine.
Old Jan 26, 2024 | 12:58 AM
BlackML550's Avatar
Lol. Its super easy. Remove the front inner wheel arch on the compressor side - there are half a dozen screws and it sits at the top of the wheel arch. Resembles and old style fuel filter. From memory it just presses on - no need for a clamp. I will look for you and see if there's a guide. If you jack up the car and have it on stands, you can do it without removing the wheel.
Old Jan 26, 2024 | 04:17 AM
BlackML550's Avatar
see this document
Old Feb 1, 2024 | 05:42 PM
BlackML550's Avatar
Additional Diagrams of Airmatic Components
Additional diagrams of componentary
