ABS active on its own
Old May 19, 2024 | 12:47 PM
Smiffy177's Avatar
Ml 320 cdi
My ML w164 has developed a fault with the following codes, 5132, 5136, 7270. This happened quite suddenly and it appeared as though the ABS was activating on 1 rear wheel. I disconnected the rear Sam unit o/s/R which allowed me to drive home. The Sam u it has been apparently b4 but it all looks good inside no water staining or corrosion on the plugs. Just a wheel sensor????
Old May 19, 2024 | 06:17 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W164 forum...
Old May 20, 2024 | 04:03 AM
Vmaxxer's Avatar
ML350 Bluetec
I had a grinding noise on one of my front wheels at low speed (ABS sound) and EPS started to brake on its own. Together with the ABS, EPS etc warnings on the screen. Changed wheel speed sensors and all is well
Old May 21, 2024 | 02:54 AM
Smiffy177's Avatar
Ml 320 cdi
Problems solved. Replaced sensor
Old May 21, 2024 | 03:47 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Thanks for posting your solution!
