I think you'rer talking about the crackshaft, I am still working on getting the timing cover off, I have the procedure down but sicne I need a seal remover and cleaner to clean up the oil pan and middle piece, I will hae to wait a few days till I get them, I already ordered.
“ You must align the cam gears to each other and the machined surfaces of the cylinder head where the cylinder head covers bolt down"
Trying to understand this:
ligning the cams to the machined surface is a must, they will not sit any other way, but with the valve open or close? Should the Intake and the Exhaust cams match, and should the Left and right sides match?
OK, you guys were right, I had to remove the oil pan.
Removed the 4 screw on the bottom of the engine mounts, 2 on each side.
Lifted the engine with my 3 ton jack about 4 or 5 inches, got to the oil pan bolts except the one on the side of the driver side (a pain to take out)
removed the oil pan and then I was able to remove the timing cover. Pried it out carefully.
I wrapped the chain after marking the yellow links and each is in it's position:
The Engine is @ 40 degrees
Crankshaft - square plastic notch
Camshaft - three notches
Intake (Left and Right) Gears - matching the letter R and the letter L
The side notches on the intake gears do not sync with the bottom of the head cover.
I rotated the engine to 305 degrees once, and then up to 6 times and still I can't see the stamps through the sensor opennings on the camshaft front covers.
I am close to lining the timing chain and gears proeprly but not there yet, any thoughts, help?
1. remove exhaust camshaft & intake camshaft at right cylinder head.
2. disconnect old chain
3.draw in new chain
4. turn crankshaft to 55 before tdc of first cylinder (305 mark on the bent pulley)
5.turn crankshaft thru 95 degree to 40 degree after ingnition TDC
6. install camshafts right side
https://mbworld.org/forums/attachments/m-class-w164/416489d1525893384-engine-timing-r-i-timing-chain-272-3-eng..pdf
paste that in your browser and it is the pdf where I obtained the info
Reason: wording
I think I need to see how the camshafts sit on the head, maybe that is my issue of not lining up the gears. A pictuer of which way the camshafts sit on the intake and exhaust sides would make thing clear for me.
After all I am new at this.
@vesiadogThis is my issues, WIS is showing this diagram with 3 bores in camshaft and my camshaft has two bores which confuses me on which way to lay the camshaft on the head and tighten the retainers. (See red arrow)
Absolutely make sure since you have 4 camshafts you are not mixing up picture and info… very easy to do.
