Window wiper problems ML w164
Old Sep 19, 2024 | 06:18 PM
ErikMB's Avatar
Question Window wiper problems ML w164
Good evening.
I have an issue with the front window wipers on my ML 164, 320, 2009 model. The wipers are working occasionally on some of the functions, such as on the interval, or when pressing the window washer, and sometimes stop working at all. When not working at all, it might function after stopping the car, open and closing the door and starting the car again. Seems as a kind of reset. But still not on all functions such as low and high speed (even it work on this functions sometimes). Checked the aft SAM box and no sign of humidity. My friend had similar problems some years ago and changed out a wet aft SAM box.
1. Are the front wipers connected to the front or rear SAM box?
2. Could the problem be in the SAM box, in the relay, in the switch on the steering wheel, even the windscreen wiper motor (lack of grounding, worn brushes or similar) or in the wiring, or rain sensor?
Sincerely, Erik, Molde, Norway
Old Sep 19, 2024 | 06:38 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W164 forum...
Old Oct 11, 2024 | 06:47 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Eric what was the solution?
Old Oct 11, 2024 | 11:12 AM
jimyj's Avatar
E320
This intermittent wiper issue on your ML164 is likely rooted in an electrical or control module problem. Given that the wipers sometimes work after cycling the car's power, it points towards a potential issue with the SAM (Signal Acquisition Module) or even the wiper relay, as both are central to distributing power and signals to components like the wipers. It's also possible that the wiper motor has issues with grounding, or there could be worn brushes causing the erratic behavior. A faulty switch on the steering column or issues with the rain sensor could also contribute to the sporadic functionality. The front wipers are primarily controlled by the Front SAM module, so I recommend checking for fault codes there to get a clearer picture of any underlying issues. For a thorough diagnosis, you'd benefit from using a full system scanner like the youcanic, which can delve into all the control units of your vehicle. Keep in mind, a basic scanner such as the Launch Creader 3001 won't be capable of capturing the full range of potential electronic faults. Lastly, have you inspected the relays and connections to ensure they're secure and free from corrosion or damage?
