Off Road Package detailed info
Old Jun 24, 2011 | 12:08 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Here's detailed info on the off-road package that will come to the US sometime later (available earlier in Europe):
Full program: ON&OFFROAD package for all eventualities
The ON&OFFROAD package for the new M-Class uses six different driving modes to optimise driving dynamics and handling safety by providing the optimum drive control needed to cope with the wide spectrum of operating conditions encountered both on and off the road. The added benefit compared to the Off-Road Pro Engineering package offered previously is plain to see: whereas before there was one optimum driving mode for the road and one for off-road, drivers now have the choice of an automatic mode, as well as two specially programmed off-road and three on-road modes.
The specific driving modes for all-wheel drive resolve a conflict of objectives that has previously hampered further development of 4MATIC and the 4ETS electronic traction system as well as ESP® and ASR. To take an example: on off-road tracks, it is important that the control systems respond very gently due to the low friction coefficients, but this makes a sporty setup virtually impossible. Conversely, a sporty basic setup impairs performance abilities in off-road terrain. In the past, the engineers always succeeded in finding excellent compromises which worked brilliantly under all conditions and continue to do so. The new ON&OFFROAD package with its specific driving modes, however, enables driving dynamics and handling safety to be optimised almost as far as is physically possible under all operating conditions by maximising networking between the individual control systems.
The system is operated using a rotary control on the centre console, which adapts the AIRMATIC settings and the drivetrain to suit the specific requirements. The six driving modes in detail:
Automatic - covers the wide operating spectrum of everyday driving
Offroad 1 - light terrain, tracks, driving over fields
Offroad 2 - challenging off-road terrain with climbs
Winter - for driving in wintry conditions on roads affected by freezing rain, snow or ice, or with snow chains
Sport - for serious driving along winding roads
Trailer - optimises start-off, manoeuvring and braking characteristics when towing a trailer
Despite so many options, the driver is never in any doubt about mode selection: the setting is made intuitively, while the driving mode selected is visualised in the multifunction display as well as in virtually photo-realistic quality on the screen of the COMAND system. If the driver selects the Winter mode, for instance, the display shows the M-Class in snow. The Sport setting displays a racetrack with red-and-white curbs, while images of off-road terrain with different profiles appear for Offroad 1 and 2. The display is interactive too: steering input and spring travel correspond to the actual values, while the graphics include additional information on the steering, gradient and tilt angles, the AIRMATIC level, the pre-selected speed for Downhill Speed Regulation (DSR), as well as the selected drivetrain settings including reduction gear and differential lock.
Irrespective of which basic mode is set, the reduction gear, differential lock, DSR and the AIRMATIC system's level control can all be adjusted individually. As with the basic settings for the ON&OFFROAD package, it is not possible for the driver to make mistakes here either. Illogical settings, which would have a negative impact on handling stability, safety or traction, are precluded. If case of doubt, the system will revert to automatic mode.
In terms of "hardware", the ON&OFFROAD package comprises an underguard, a two-stage transfer case with reduction gear, an inter-axle differential lock and enhanced AIRMATIC functionality that allows a maximum ground clearance of 285 millimetres and a fording depth of 600 millimetres.
Off-road data at a glance*
Attached Thumbnails Off Road Package detailed info-off-road.jpg   Off Road Package detailed info-off-road-functions-sm.jpg
Old Jun 24, 2011 | 08:45 AM
Stesl's Avatar
04 sl 500, 07 ml 320 cdi
nice, where did u found the pics?
wich is the off road reduction ratio? 2,93:1 as the old?
Old Jun 24, 2011 | 10:53 AM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
Does this mean that a rear diff lock is no longer supplied with the off road pack?
Old Jun 24, 2011 | 11:54 AM
Off Road Package details
Daimler global site.
Don't know anymore than what's here.
It does not mention a rear diff lock, so that may be the case.
Old Jun 25, 2011 | 09:31 AM
Stesl's Avatar
ok ty
it's now all eletronically controlled via the brake
Old Jan 9, 2012 | 01:17 PM
grane's Avatar
GLK350, SL63 AMG
ok ty
A questionable solution at best. What happens if you have one wheel in the air?
Old Jan 9, 2012 | 03:20 PM
That wheel is braked and power is transferred.
Old Jan 9, 2012 | 08:24 PM
katiesdad7's Avatar
2012 ML 350 BlueTec
Then your flying! :-)
Old Jan 10, 2012 | 10:22 AM
300DTurbo's Avatar
300D Turbo 1984
This system has a "fatigue point." After a certain temperature or time that the brakes have been working as a "differential locker" the vehicle will no longer be as effective in "braking the free spinning wheel."
Old Jan 12, 2012 | 10:50 PM
True, you're not going to do the Rubicon in this vehicle. But for limited off road it is an inexpensive and low-maintenance system.
Old Feb 21, 2012 | 02:19 AM
Jeanreau's Avatar
997 Turbo GT Silver/Cocoa (sold) 2009 C63 White/Black (sold) 2012 GL350 Pall/Black
Is there going to be a similar package for the GL?
Old Mar 20, 2012 | 01:32 PM
Stesl's Avatar
yes also on the GL class
