Mirror lights ?
Old 12-23-2011, 12:04 PM
  #51
MBtech1098's Avatar
10 speed bicycle
There is...they may not be aware of it, tell them to re-SCN code the EZS. (EIS)
Old 12-23-2011, 03:12 PM
  #52
lizardking1's Avatar
2012 ML350
Anyone find out if a real fix is in place?
Old 12-26-2011, 01:31 PM
  #53
2012 ML350
The dealer today said they can't check it since it's not dark out and they can't seem to trick the ML in thinking it's dark. Now, I'm stuck going to another dealer to see what they say.
Old 12-27-2011, 10:29 PM
  #54
dougiebear's Avatar
2013 ML BLUETEC JULY 31
Originally Posted by msim
So, dealer looked at it and say it's part of the P35 lighting package (which I don't have). I checked MBUSA.com and it lists "Night Security Illumination" as a standard feature, not optional. Further, the P35 Lightin package only lists the Bi-Xenon headlamps with Active Curve Illumination, Adaptive Highbeam Assist, Corner-illuminating front lamps and Headlamp washing system in it and none of those sound like this. I'm not sure if this is something that MB has not included it on early models, etc., but I feel misinformed by someone here. MB product specialist is giving a call.
In Canada P35 is part of the AHA BI Xenons. I think ur dealer is thinking of the interior lighting pkg or ambient lighting. By pkg I don't mean option each country sets up what is standard but its still a pkg each country has to order from MBUSI
I think in the past it was part of Xenons pkg in USA both were std in Canada MY11
Old 12-28-2011, 03:36 PM
  #55
katiesdad7's Avatar
2012 ML 350 BlueTec
I have the diesel and they work fine on mine.
Old 12-28-2011, 04:02 PM
  #56
jtorrebl's Avatar
2020 Panamera GTS
It was stated in this thread that diesels are fine
Old 12-28-2011, 04:33 PM
  #57
sicce's Avatar
2012 ML350
Email Response from Customer Services - on this issue
"We can confirm Germany is aware that is feature is not available in this model. They are looking into whether these vehicles can be coded to offer the locator light. We would suggest checking with your dealer in few months to see if there are any updates."
Cannot believe that you have to wait for a few months to find out, if a feature that is included as standard will work or not
Old 12-28-2011, 05:07 PM
  #58
2012 ML350
If not, I would hope they would compensate us.
Old 12-28-2011, 06:59 PM
  #59
TundraRoads's Avatar
2012 ML350
Nope. I want them to work.
Old 12-28-2011, 07:01 PM
  #60
2012 ML350
I want them to work as well....but it's not looking good. Nobody has had success to get them repaired or has any real information as to why they don't work.
Old 12-28-2011, 07:10 PM
  #61
jweezy's Avatar
Mercedes-Benz ML350
I want them to work too...
I think it would be a great deal of luxury to unlock my doors when walking to my car, and the entire area around my door is illuminated.
Old 12-28-2011, 07:13 PM
  #62
2012 ML350
What concerns me the most is the fact that Mercedes claims that they perform a series of quality checks. I guess checking all the lights isn't part of the checks.
Old 12-28-2011, 08:03 PM
  #63
2012 ML350
My past two trucks have had this as well as my wife's previous car. Don't plan to go without. Hopefully any concerns about MB not getting this corrected are rumor and misinformation.
Old 12-28-2011, 08:10 PM
  #64
2012 ML350
I emailed MBUSA from my owners support page to ask about the issue. I explained that I have already took this issue to one dealer with no success. I let them know that I setup another visit with a different dealership. I asked them what they plan to do to resolve my lights not working. Will see what they say.
Old 12-29-2011, 01:12 AM
  #65
jtorrebl's Avatar
2020 Panamera GTS
What about this fix? Has anyone tried this with their dealer?
Old 12-29-2011, 09:07 AM
  #66
MBtech1098's Avatar
10 speed bicycle
If the dealer does not know, ask them to contact their factory rep. He will then advise them to do what I had mentioned earlier. I have already done this on three vehicles and it works.
Old 12-29-2011, 10:01 AM
  #67
Scott5000's Avatar
2012 Blk/Blk ML350 4Matic
Thanks MBtech, sounds like a super easy fix. I take it this is just a body control module reflash?
Old 12-29-2011, 11:26 AM
  #68
MBtech1098's Avatar
10 speed bicycle
Mercedes does not use what is called a body control module, multiple control unit handle the tasks of body functions. The EZS is the electronic ignition switch, it is also the central gateway on a 166 chassis. The central gateway is in a sense almost like a router would be on a home network. The 166 has about 8 separate networks it basically translates signals from one network and communicates them on the others. If a certain feature is not coded in the vehicle, then the gateway does not pass the information along.
This what has happened with the puddle lights. They were not correctly coded in the gasoline vehicles. All the coding strings have been corrected, when you go to the dealer they will rewrite the corrected SCN coding, it is not a flash, and it is very quick to do.
Old 12-29-2011, 04:04 PM
  #69
katiesdad7's Avatar
2012 ML 350 BlueTec
It has to do with the spark plugs. Because that's the only real difference between the gas and diesel. :-)
Old 12-29-2011, 04:18 PM
  #70
2012 ML350
mbtech, thanks for the explanation on that. Always good to know how things work (and don't).
Old 12-29-2011, 06:27 PM
  #71
Scott5000's Avatar
MBtech thanks for the detailed explanation. Thanks for helping and contributing to the community. MB should give you a raise.
Old 12-29-2011, 06:50 PM
  #72
MBtech1098's Avatar
10 speed bicycle
...MB should give you a raise.
Haha, thanks. Let me know how you make out with this one. . (all and all MB has been good to me.)
Old 12-29-2011, 07:29 PM
  #73
T Class's Avatar
2015 CLS400 | 2009 S550
Here's what they told me @ Beshoff in SJ about this.
They said that they could not fix the recall yet since the manufacture still have not sent the information to the dealers to fix the issue.
Old 12-29-2011, 07:32 PM
  #74
2012 ML350
Figures.......
Old 12-29-2011, 07:48 PM
  #75
MBtech1098's Avatar
10 speed bicycle
It is not a recall (as of yet, not sure if it will).
You need to tell the dealer you are not satisfied and don't believe them. Like I stated tell them to contact their factory support...and guess what they will tell him, do it!
Quick Reply: Mirror lights ?
