Random Stalling in 2012 ML
Old Apr 18, 2012 | 07:16 PM
  #51
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Fuel pump issue?
Tech's two cents: https://mbworld.org/forums/new-m-cla...complaint.html
Old Apr 18, 2012 | 10:18 PM
  #52
NJProTech's Avatar
MANY
Originally Posted by katiesdad7
My Prius shuts off but you don't notice it since all the stuff is run on electric. The A/C and stuff. But it takes a certain kind of engine to do this. I know you have to have the water pump and oil pump still pump after the engine is shut down.
Transmission oil pump and a/c compressor need to keep turning. They're electric driven on Eco engines.
Old Apr 18, 2012 | 10:52 PM
  #53
mcube3's Avatar
2012 ML350 BLUETEC, 2011 Audi A4 Avant
I am starting to worry a bit. Does it affects "Gas" engines only?
Old Apr 22, 2012 | 03:23 AM
  #54
trident9440's Avatar
ML350
Originally Posted by ML12NYC
I just realized that the transmission stayed in D. Thanks trident9440 for posting your experience because we now know that this is not isolated to Keyless drivers.
I will add:
The stall occurred after driving for almost an hour from highway driving to slight aggressive NYC driving (taxi style driving...switching lanes, etc). As soon as I a made a complete stop at a light the truck stalled.
Yes ML12NYC, I would agree with you that you need to drive this car for at least 20 min. And both times I did a sharp turn after the freeway drive. I remember I used the shift paddle as well.
Old Apr 23, 2012 | 11:03 AM
  #55
TundraRoads's Avatar
2012 ML350
Another stall in mine last night. Came off the freeway, up the exit ramp to a stop. STALL. Took three attempts to get it to start again. Drivers behind me were extremely unhappy.
None of mine have involved paddle shifters and four have not involved any turning between freeway exit and stall. Three have involved turns.
I believe every one was the first time I came to a complete stop after exiting the freeway, though the first might have included one successful stop & go before the stall.
Fuel pump makes sense. What really scares me is if it happened from some sudden change in speed on a highway like quickly braking instead of only happening at a complete stop which could still be dangerous but much less than on a highway.
Old Apr 24, 2012 | 01:12 AM
  #56
vtsnake's Avatar
cclass
To those with STALLING issues: can you please tell me what state you are from? I have noticed when I do a search on mbworld for threads with stalling issues, I have mainly noticed two things:
1. Most of the issues are from NJ or NY
2. Most involve exiting the freeway and going through a turn.
This is not just on the W166. There are other chassis's with the same issue from the NJ, NY area.
I am mainly interested to see where this is happening because I find it strange that it is happening on the east coast. Maybe it truly is a gas issue?
When I can get a hold of my MB Master Tech friend at the dealer, I am gonna pick his brain to see what he knows. Probably Friday when I go pick up some parts.
Anyway I hope you all get this figured out!
Old Apr 25, 2012 | 05:14 PM
  #57
NJProTech's Avatar
MANY
It's the fuel pumps. I already started a topic for this. If its occurring on your vehicle and there are no fault codes you have a faulty high pressure fuel pump. And Yes, all my friends at other dealerships are only seeing this issue in NY area.
Old Apr 26, 2012 | 11:22 AM
  #58
2012 ML350
It is not just NY. Same problem has been reported to dealers in IL, MN, OR, and NV.
Old Apr 26, 2012 | 02:56 PM
  #59
socalML350's Avatar
2012 ML350
Angry stalling at stops
I have a 6 months old 2012 ML350 with about 4k miles and have experienced 2 stalls.
1. Both happened after getting off the freeway and coming to a stop at a signal at the exit.
2. I am in Southern California. Weather was perfect S Calif weather in both cases (no rain, cold, etc).
3. I don't have keyless entry.
4. I switched from Mobil premium to Shell premium after the first stall as the dealer mentioned that bad gas was a probablity. I have used both stations for my Lexus fillups for the past 7 years and not had any problems.
5. The dealer had my car for a day after the first stall but did not find anything.
6. In the first case, the car shuddered before stalling. I don't remember a shudder before the 2nd stall.
7. On a few additional occasions, I have felt the car shudder, but it didn't stall.
The above is quite similar to what everyone else has experienced. The only thing I would like to add is that I was on an upslope in both cases.
Wish I had stayed with Lexus.
Old Apr 26, 2012 | 04:29 PM
  #60
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
So does Mercedes now use a different high pressure pump to replace the "new" one that was installed at the factory?
Can anyone post a part number for the "new newer" pump?
Old May 5, 2012 | 02:20 PM
  #61
chelentano99's Avatar
2020 GLE 450 $84k MSRP
I got my 2012 ML350 shudder 3-4 times in the last 3 days. It did not stall yet but it makes me nervous. It happens after the car is parked for a couple of hours (not on stop light nor freeway). I will be watching it. I am in Chicago.
Guys, please keep us posted if you find out a fix.
Old May 5, 2012 | 07:36 PM
  #62
sshu930's Avatar
03 M5
If the people who are having the problems could give the build date of their vehicle maybe we can see if this is an issue with specific build dates.
Old May 6, 2012 | 12:31 AM
  #63
ML350
The high pressure pump was replaced. Enginee stalled again 3 days after get the car back. So the high pressure pump did not fix the problem. Btw, how to check the build date of the car?
Old May 6, 2012 | 02:52 AM
  #64
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Build date is stated on the driver door jam on a sticker. I believe it's listed above your tire sizes.
Old May 10, 2012 | 10:40 PM
  #65
2012 ML350
Mine is 11/11
Old May 10, 2012 | 11:08 PM
  #66
GA350's Avatar
2012 ML350
Does it affect bluetechs only?
Old May 11, 2012 | 08:46 AM
  #67
krazyvshank's Avatar
2008 Honda CR-V, 2013 ML350 on order
I've seen people report it for the gas engine too. Hope they fix it in the 2013s
Old May 17, 2012 | 10:40 PM
  #68
ML350toy's Avatar
S2000
Got our new ML350 last week, gas version w/ P2. We were excited to drive around for no more than 200 miles in less than a week, and guess what? The car shook and stalled at a traffic light during a local trip. Now the car is in the shop. Dealer unable to determine the cause from the diagnostic code and waiting for the advice from Mercedes' headquarter on what needs to do next... Just like the very first post of this thread, service advisor says it might be "bad gas" and I told him that I was still driving from the same gas that the dealer filled up with. Anyway, hope this would resolve soon b/c I have not had a car stalled on me for a long time, from Toyota Corolla to Honda Accord, but yet my brand new Mercedes already in the shop within the first week... Will post update when hearing back from dealer.
Old May 18, 2012 | 12:15 AM
  #69
2012 ML350
I believe it is ONLY petrol/gas engines. Bluetec's come with their very own bucking issue.
Old May 18, 2012 | 09:25 AM
  #70
300DTurbo's Avatar
300D Turbo 1984
Originally Posted by ML350toy
service advisor says it might be "bad gas" and I told him that I was still driving from the same gas that the dealer filled up with. Honda... Toyota...
Irony in the finest form.
K.I.S.S is the philosophy of the Japanese automakers. Not found in Germany.
Its the sheer complexity of these vehicles.
I'm assuming the German test team did over 1,000,000 cumulative miles with these vehicles before signing on the dotted line to start production? Why didn't they pick these issues up?
Manufacturing issue?
Old May 18, 2012 | 11:37 AM
  #71
batuceper's Avatar
[quote=300DTurbo;5201725]Irony in the finest form.
quote]
I remember the days (1970s) when MB advertise their cars as "engineered like no other car!"
Guess they have not changed!
Old May 18, 2012 | 01:44 PM
  #72
raspberry's Avatar
2011 ML350 4MATIC
Defective Speed Sensors
have 2010 ML350 4MATIC - stalled about six months ago with an ABS warning. took it in and they diagnosed it as a faulty speed sensor. happened again a few days ago. took it in and was diagnosed with a SECOND faulty speed sensor. the thing just died in the middle of traffic - twice! no turns, not sudden maneuvers or changes - just flat 30+ mph driving. scary to think that it could just shut down so randomly like that. so there are FOUR total, but they won't replace the other two proactively. now I must wait for them to fail before getting them replaced - the fact that the service center had them in stock should send a clear message re how systemic the issue may be... hope that helps some of you. not sure if its the same issue...
Old May 18, 2012 | 07:41 PM
  #73
katiesdad7's Avatar
2012 ML 350 BlueTec
I don't know what is worse the constant bucking of the diesel for the first 30 seconds or the possibility that the gas engine will just shut down.
Old May 18, 2012 | 09:23 PM
  #74
ML350toy's Avatar
S2000
okay, picked the suv up today. local dealer said that the suv was indeed having a faulty high pressure fuel pump and replaced, as someone had mentioned at the beginning of this thread. local dealer was unable to extract anything wrong from the diagnostic code, and this is the advice that mercedes headquarter recommended. anyway, i hope this would resolve the stalling issue.
Old May 18, 2012 | 09:34 PM
  #75
F18BEN's Avatar
Veteran: Army
2026 BMW 550e X DRIVE, 2024 GLE 450e SUV
What's weird about this stalling is that the same engine is in the E350 and there is no mention of a problem anywhere on their forum. It has to be something that is different on the ML.
