Breaking in new 2012 ML350 Bluetec
Flights are cheap. Certainly well worth the cost of sparing an engine I hope to see run for 200K miles.
IMO, the most important thing for a new motor is to vary the RPM and not cruise at a constant RPM.
Can you drive at off-peak hours where you won't hold up traffic (and p^ss off drivers) and be able to drive at 65/55/70/60/75/50 mph? If you can adjust your schedule and vary your speed, this could be a great trip for break-in.
If you must drive with traffic flow and cruise a steady speed, then it might be better to not take the new M.
Enjoy the new M
FYI Gang, having been in an Ontario assembly plant it would scare you how assemby ends.
Every vehicle MUST hit the rev limiter then back down to 0rpm or it don't leave the plant. UR brand new motor had the **** oops run out of it before you got it :o)
Enjoy and play around a bit on a warm engine lucky guy.
I bought a new Trooper II on a Saturday in Louisiana. The following weekend I had the oil changed at Old Faithful in Yellowstone. The next weekend I had the oil changed back in New Orleans. 15 years later I gave the old Trooper to my daughter. It always ran fine. No cruise control during that 5,000 mile first two weeks. No cruise control at all. That varies the RPMs.
If I were you, I would head more west firat. Go around NYC. Cross the Hudson on the Newburgh–Beacon Bridge at Fishkill, NY. Then angle south. I did that one afternoon between 2pm & 6pm. Cruised at 65+ from NJ to NH. NYC is for the natives. The reat of us can go around.
Wayne
Got 296K miles on the 300D still running strong , drove it from Chicago to Cali within the first week. ENJOY the vehicle. Life is finite. Your engine will be fine.
