Running Boards Myth?
I don't think the belief by many here that running boards dirty your pant leg more than an ML without them is true.
The ML without running boards have protruding side sills are not covered by the door when closed so they are exposed to the elements. And when you exit you have no choice but to rub your leg against the side sills creating the same result.
There are other cars that cover the side sills with a closed door or the side sills are recessed/angled inwards. Neither is the case in the ML. So running boards or not, you still wipe the outside of the car with you leg exiting.
My experience is living in SoCal, and for the most part, the cars here just get dusty. I wonder if it is different in more inclement weather areas and if there is more build up/dirt on the RBs than side sills.
Then again, I imagine if living in inclement areas the RBs will help avoiding having to stepping in the muck.
The aesthetics are subjective. I strongly prefer them with. And it seems the board here is split with that regard. To each his own but I'm interested in others real world experience and objective reporting with the RBs and without.
The appearance factor is not a big one with me one way or the other but I really don't think it adds to it. My ML came with the boards, as did a heated steering wheel which is another thing I did not want, especially here in Texas. But these were minor issues since it was the only ML I could find anywhere that had all the other things I really wanted and in the exact color I wanted. Bottom line is I would not pay to have them put on or special order them. But since I have them, I can live with them.
Appearance is subjective. To me, they appear ugly. Does Porsche offer boards on the Cayenne?
It does for me and everyone in the car that has conducted this "experiment" that I've tried it with when test driving.
Anyone with the AMG sills will find it even more difficult to not rub because they protrude even farther than the non-AMG sills.
Likewise for the Lexus RX - terrible "truck" but moms love it and no boards. I don't imagine the step-in height of the RX is much more than the W166.
I agree with your point that if you exit and don't use the RB as a step than you will get dirtier compared to no RBs. But without RBs you will almost be assured to get dirty.
One way for MB to get around this is to design the door to cover the sill and have anything below it angle inwards as some other cars do. It is an interesting design point that I now look at on cars in general.
She says it's great without the boards because she can lean into the vehicle to get her kids (3 and 2 yrs old) strapped in without getting her pants dirty. With the boards, she couldn't get close enough without leaning against them. FWIW, this was an unprompted convo.
And the AMG sills don't stick out any appreciable amount further than the standard sills.
1) You're leg length: if you're tall, your leg naturally reaches out further when getting in or out. But if you have shorter legs, then you're more likely to touch it.
2) If you have AIRMATIC (MLs with AIRMATIC sit lower when stationary): When the car is lower to the ground, it is less likely the inside of your leg will touch the running board. I believe ML63s may sit even a smidgen lower.
3) Drive in an area where the running boards are prone to accumulate dirt, mud, etc. If you drive around So. Cal., for example, where it rarely rains, you might not be bothered as much.
One other thing: my dealer also recently told me about issues they are having with the newer (2012+) running boards that have the egg-shaped rubber 'grippers' on the top surface. These have a tendency to come off, he says, unlike the previous design. Although the newer design is supposedly less protruding than the older, so less likely to touch your leg.
In any case, running boards remind me of having training wheels when I was a kid. I think they also make the ML look more feminine. While they're not bad looking, I prefer the 'twist bars' on the AMG body style. So, once my ML550 arrives with the standard running boards, I'm immediately swapping them out with the twist bars at an estimated cost of about $1,200.
ML350 (non-AMG trim) with running boards:
ML350 non-AMG trim without running boards:
ML550, AMG trim, with running boards:
AMG trim without running boards ('twist bars' instead):
AMG trim without running boards ('twist bars' instead. Note this ML350 with the AMG kit is only available outside of the US, i.e, Canada):
