Internet on Ml350
Old Nov 16, 2012 | 06:30 PM
emran's Avatar
ML 350 Bluetech 2013 Loving it!
Internet on Ml350
I have command system on my ML350 .
Will the internet work on this ?Do I get connected via my mobile phone ? or do I need another connection ?
How does this work ?
Old Nov 16, 2012 | 06:37 PM
rexgold's Avatar
GLC43AMG Polar White, 21" Alloys, Prem Plus Package, LED Intelligent Light, 360 Camera
What phone do you have?? If its an IPhone, then you are out of luck... Something is not compatible with the 2 so can't use it.. I believe some android phones work just fine.. I have an iPhone and its not working...
Old Nov 17, 2012 | 02:30 AM
dfulgo's Avatar
2020 - G63; RR.AB; ML350; ML320; ML400; M3; 200CE; 200E
It is fine with Android (Samsung Galaxy Note II) provided you get the app that let you share the connection (BlueDUN).
Old Nov 17, 2012 | 07:47 PM
sp00ky's Avatar
ML350 (W166) / CLK 320 Avantgard 2002 W208
An app to enable outdated connectivity. MB should have sorted this years ago - it should just require a software update to add the PAN bluetooth stack and so it's not exactly difficult.
Old Nov 17, 2012 | 11:20 PM
fabbrisd1's Avatar
A gaggle of MB's
No, PAN would require a different chipset I believe..
Old Nov 18, 2012 | 04:32 AM
sp00ky's Avatar
PAN is simply a profile that is added to the stack, the same as DUN is a profile, and this surely should have nothing to do with chips - it can be programmed. If this wasn't the case then an app would surely not enable PAN on android phones.
Old Nov 21, 2012 | 03:22 AM
Thimee's Avatar
S550, SRX, ML550
Haha, I saw the: "PAN in Bluetooth? No you're stupid, no you're stupider" argument over on the Benzworld forum earlier...
For what it's worth, I saw an interesting article on the subject that suggests that Mercedes will indeed include PAN in some of the newer versions of their Bluetooth stack:
http://telematicsnews.info/2011/08/2...online_ag2223/
Old Nov 21, 2012 | 04:51 AM
sp00ky's Avatar
That is over a year old and stated that there would be a solution in the second half of 2012, so it's not worth much... That's not happening based on the information that I have been given.
