Do any ML350s have Ceramiclear paint?
From Dr. Ghodoussi...
"After the "cerami"clear top coat is sprayed, the nano particles of Fumed Silica (SiO2), which are synthetically engineered, migrate to the top 0.2 mils of the clear coat as it is curing.
If you remove this potion of the clear layer of paint, the paint under it will be much softer and will not polish out or react the same way the nano particle portion did or would.
You will at some level have compromised the the finish on the car".
That said - the clear coat used on your Diamond White" does qualify as a "ceramic clear coat" of a different type described by the "Dr".
This is straight from my collision guys - who not only are MB Certified but are also certified and highly respected nationwide on the AMG finishes as well.
Frankly, for best paint protection for your new Diamond White I personally would recommend a "polish" such as Einszett Glanz Wax (Blue top) or a Black Fire polish product.
With a correct polish on your clean/new Diamond White - then any add-on wax on top can easily be done with a spray "nano-carnuba".
With the specific Einszett product, tht is a wipe-on a smooth thin coat, let dry/cure for 30 min, and then wipe off the haze with a microfiber towel.
Keep the beat !
http://www.autogeek.net/1z-einzett-products.html
Big misunderstanding in "detailer" world - where old-school-heavy-wax-heavy-buffing became the somewhat-sick thinking here in the US..
In the past I have used two product lines I like very much for white and light colored cars - Klasse and Duragloss. Klasse All in One for the polish/cleaner and their Sealant Glaze as the last step product. Great looks and durability and also German made, or at least German created. I even made a home brew spray of 1 part Sealant to 3 parts distilled water and it worked pretty good as a spray topper. Lately I have used Duragloss polish and sealants (their 111 is especially good on white cars), topped with a spray of their AquaWax that actually bonds to any of their sealants. Good stuff but I am anxious to try the Einszett line as well.
I decided to experiment with my new Einszett by matching it up against two of my favorite after wash "toppers" - Optimum Spray Wax and Duragloss AquaWax. All three are not true waxes as I understand they have some polymers included and are as much sealants as they are wax - almost hybrids in formula and chemistry. I used the Einszett on the hood, both rear door panels and rear hatch area; the Duragloss on the front right side panels and the Optimum on the front left side panels. I did not spray wax the roof at all this time around.
I took a strong work light and went all around the vehicle. I could not tell a bit of difference in gloss (they were all terrific!) and all three were smooth as silk to the touch. The Optimum went on easiest in that it buffed out right away while the Duragloss seemed more "liquid" and required several more passes to buff out, even with a very plush "chinchilla" microfiber towel. Then again, I might have sprayed too much product on the panel as it did seem to have a much more powerful sprayer than the other two. Einszett was similar to the OSW in application. Basically, all three can be applied as you would "quick detailers" in that they are spray and wipe products.
Now I will determine which of the three protects the best and lasts the longest, although I realize the Einszett will be at a little disadvantage because the hood is a horizontal surface. However, I will still get a good reading as far as dust attraction and ease of future road grime, bug and tar removal.
Time will tell I guess but as of right now I can only conclude that most major spray wax "toppers" and maintenance sprays are fairly equal - at least on Diamond White. Of the three I used Duragloss would probably get the nod (at least initially) because it can be found in some NAPA and Carquest stores locally (I believe the others have to be ordered by mail) and because it is by far the cheapest. It takes a little longer to buff out as I said before but not terribly so.
Incidentally, I also ordered the 1Z Einszett vinyl/rubber treatment spray and used it on the engine, window/door rubber seals and exterior moldings, as well as on the dash and interior parts (except seats, steering wheel and pedals because the directions said not to). I was very impressed with this product. It made the black trim and rubber blacker but not shinier, if you get my meaning. It seems to be as good as Protectant 303 and that is saying a lot!
