Anyone try to connect portable usb HD and iTune lib?
I bought a 500GB portable USB 3.0 hard drive and copied my iTune library to the drive. When connected to ML350 using the MB factory USB cable, nothing happens
Any idea or suggestion?
The data port will accept memory players that have a USB output.
500 GB drive - that's a lot of music - 128GB flash memory USB sticks are "better" grade about $140
The 500GB Portable HD I bought (cost about $55) may NOT be equivalent of "flash drive". But it still does no need any external power. The power from the USB is sufficient like "flash drive"
I think I am going to try a USB 2.0 portable drive or a real flash drive to see if which one works next.
On computers, this usually isn't a problem because most modern computers allow devices to draw more than 500mA - technically, outside of the standard spec. An iPad for instance needs 2.1A (2100mA) to charge properly - way outside of the USB spec.
USB 2.0 ports on devices other than computers (like our cars) usually stick to the specified standards and don't provide extra current beyond the minimum specs.
I will try the flash drive next. Anything over 128GB will be expensive.
I have over 300GB of iTunen music that I would like to play in the COMAND. Looks like there is no solution out there yet due the the limitation of the COMAND
- try a different hard drive that uses less power. It varies by manufacturer
- supply additional power to your current hard drive via the 12V power port and the necessary adapters
Another thing to consider - you didn't specify how you copied your iTunes library to your hard drive and what format your music is in. If all your music was purchased via iTunes, then it is most likely in AAC format, not MP3. COMMAND definitely plays MP3 format, but I haven't tried AAC. Many 3rd party players do not support AAC, outside of Apple devices.
I was curious so I tried a few experiments on my end. I used an extra 1TB USB drive I had and loaded a few music files on to it to see if the car would play them. Here is what I found:
1. drive must be formatted in the FAT32 format
2. power doesn't seem to be an issue
To the OP, my first question would be - what type of computer are you using?
If you are a Mac user, you must use disk utility to format (erase) the drive and reformat it in FAT32 format. You can then copy your files over again and see if they play.
If you a PC user, go to My Computer, right click on the drive icon and select Format. Choose FAT32 (not the default NTFS) to reformat the drive.
The reason that you don't have to do this on flash drives is because they are smaller, they are formatted in FAT32 format by default. Hard drives are formatted in NTFS (PC) or HFS+ (Mac) by default and the car doesn't support these. FAT32 is a holdover from the MSDOS days and while universal, is less efficient than the newer formats which is why larger drives don't use it anymore.
I was able to export playlist to DVD and play in COMAND
But that's just 4GB.
I would like to copy my entire iTune library and play in COMAND. My library is over 300GB. No iPod or iPhone has this capacity
So this is why I am trying USB flash drive or portabel drive.
I check the COMAND manual for supported devices and in deed, the format must be FAT32. The portable HD I bought is NTFS.
I am running Win 7 64bits so I could not even reformat it to FAT32. Only NTFS or exFAT is supported. I will check out to see if exFAT is backward compatible with FAT32. If not, I will get another FAT32 HD.
Thanks a lot!
Open a command prompt as an administrator, and use the command line
format <drive>: /FS:FAT32 /q
where <drive> is the drive letter you want to format. (Dont forget the colon). If you don't want to do a quick format, remove the /q parameter.
It's painfully slow - 28% since the last 2 hours.
- Make sure/format the USB portable HD is/to FAT32
- Simply Drag-and-Drop the iTune directory into the HD
- Plug the HD to the USB port inside the arm-rest compartment
- Select USB Storage from the COMAND and play
- The whole lib is imported including the album art works too
- Enjoy you complete iTune library without iPod or iPhone
thanks for all the helps!
