Frank gets new winter boots (pics)
A project started from scratch
It was an occasion for convincing impressions of the Scorpion Winter tyre that replaces its predecessor, Scorpion Ice&Snow, and of the development on which Pirelli engineers, as confirmed by Stephen Rowe, project head for the SUV platform, “started again from zero with the innovations that had been introduced to all the components, tread pattern, compounds and structure”. In effect, the comparative data represented by the customary web chart (and the relevant 255/55 R18 size) show a really considerable leap in performance. Moreover, the two products are separated by a decade. “For braking on snow from 50 km/h to zero, the distance has been reduced by 10%, whereas traction capacity measured between 10 and 40 km/h has increased by 9%; for dry (from 100 km/h to 0) and wet braking (from 80 km/h to 0), the improvement is 1.7 and 2.5 metres, respectively. Internal and external noise has also been reduced (3 db lower than its predecessor) in addition to rolling resistance that can guarantee up to 4% more fuel efficiency.” According to the plate data, dry and wet handling and control have also been significantly improved, but it is handling on snow that has benefitted the most from the development process - 13% better than the previous model’s performance. The tyre seems to be well balanced in relation to the different conditions of use and performance, from traction on corners to grip on slopes and when braking.
Sporty handling
It is the outcome” – Rowe explained – “of the specific shape of the blocks and sipes, which gives longitudinal and lateral thrust no matter which way the tyre is facing. The directional tread pattern has been optimized primarily in terms of braking, with sipes on the central rib, which also go into action when steering, and the radial orientation of the external sipes helps traction”. At the sides of the rib (with angled blocks giving it an arrow shape), even the grooves, two or four depending on the size of the tyre, have been designed to improve grip by channelling water away from the surface. The new Scorpion Winter tyre can be felt directly in the steering wheel and this gives a reassuring sensation of control. The development of the new product, which took 3 years and 300,000 km of tests carried out between -32°C at the Arctic Falls proving grounds in Sweden and 8 degrees at the Idiada circuit in Spain, was, without a doubt, aimed at offering the confidence that SUV enthusiasts are accustomed to when driving with summer tyres. The declared objective was to make more powerful models more agile and with better handling in the different conditions typical of winter. Then there is comfort: a 72 block pitch to reduce rolling noise and a rounder tyre profile to take advantage of the compound’s characteristics rather than the lateral grip of the outside edges.
A generational leap
The compound” – Rowe said – “incorporates new-generation functional polymers that are pre-treated to make them more receptive to bonding with the silica and carbon black by using special activators. We also discovered a way of using more silica (to give greater wet braking and less resistance to rolling) without compromising the dry performance given by the carbon black component”. Also making a contribution to handling is the softer and more elastic belt beneath the tread, while the improvement in smoothness is without doubt due to the reduction in tyre weight. The other characteristics include one that is shared with the PZero – inscriptions in relief on the sidewall to prevent aerodynamic interference. Not unlike the development of the Diablo Rosso II tyre created on the basis of the demanding specifications of what was then the new Ducati Diavel, in this case the Scorpion Winter (Pirelli tested five different designs before deciding on the definitive version) was based on the requirements of the new Macan, the compact SUV from Porsche. Made in Great Britain at the original equipment factory, and in Romania for the other sizes, the new tyre is being homologated by Porsche and Mercedes and will be sold in the autumn in 28 sizes from 16” to 21” and in a runflat version.
http://www.pneurama.com/en/rivista_a.../Tires?ID=6940
http://www.tirerack.com/tires/tires....omCompare1=yes
With the physical property (size) and somewhat closed tread and attitude on ice (dunno if it's the tire or vehicle) I'd give them a rating of 4 and say they were the wrong choice.
My .02 cents
My Escalade with awd and Blizzack DM-v1 seemed to perform better,,,awd system with tires and ability to disable traction control by holding button = better winter driver
so have appt. this Tuesday to install Michelin XiceXi3
ordered 255's (same as summer front) but -
it was suggested 245 or even 235
Mostly in-city driving but from what I sense here the narrower tire tread may have been a wiser Winter choice
No snow here as yet (Toronto, Canada)
My .02 cents
Were you driving 'fast' or you think the tires are just too large?
I hope my Dunlop 3D 255/40 tires Will perform better
1) quiet running
2) appearance (width/profile)
3) ride
As in the better winter tire is coarser blocks (if mostly deeper snow drivin..ice finer is better), taller (larger side wall for softer ride) and narrower (better turning performance and cut through traction)
1) noise/quiet
2) ride/comfort
3) performance
Almost bought the Michelin Alpin - but the Tire Rack survey rated X-Ice higher based upon my criteria plus there was the supposed bonus of better tread wear although after 1/2 wear - time for replacement - not really a fan of Michelin but given the top 3 this was my choice - replacing Yokohama - don't get too crazy in winter conditions enough crazies out there already!
PM me if you are interested.
I bought the same rims and tire size (stock 20 amg) so i don't get it!! No spacers no nothing! It doesn't make sense to me since my inner fenders weren't modified:-(
While tire width is a consideration you shouldn't drive in snow any deeper than the height of the tire sidewalls, that rule of thumb goes for all winter tires. I have the same 265 width tire but w a 65 /sidewall height % on my other SUV and they've been going through pretty deep snow for years, 265 width isn't an issue.
I also have Nokian NO 295/30 19" (staggered rears) on my Porsche Turbo (all wheel drive, summers are 305's) that I switch to every Winter (mostly because of tire composition in below freeing temps... I dont choose to take it out in snow but if Im already out in the car & it does snow as long as long as its only an inch or so I can thread a needle w/ the car/tires.
Main point - You cant expect to drive in a foot of snow with 265/45's/ sidewalls that are only 119mm/4.6 inches tall.
Also, make sure you put on at least 50-100miles on dry pavement before using tires in the white snow.
EVO - 255/55 = sidewalls that are 114mm so actually less than the 265/45 which are 119mm tall so the rubbing shouldn't be that. Could have something to do w the width & height of of the tred on the Dunlops.
and a very odd trait with these on ice..and I don't know if it's the tire that manifests it or other but the truck especially the rear gets very nervous..twitchy..skirmish..a very scary feeling like it gonna break loose and this is simply cruising at a moderate speed on a flat surface Icy only)...I don't know if it's because I reduced the psi down to 35 from the 46 (joke) the dealer put in...or if it's because I lowered it (doubtful) or....because the unit runs such an agressive camber spec and one tire is forcing the others fighting over traction...such a wierd uncomfortable feeling..dunno
