Valentine 1 Hardwiring in the ML
I have a Valentine 1 that my prior vehicle could be hardwired directly into the rearview mirror using a short Invisicord. I realize that we have to hardwire into the overhead console on the ML. But what aftermarket product/cord are people using for this?
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
Look for my post..I can help you or possbily you already did..
Use the invisicord via power from overhead console light from inside console
Yup...12" or longer the better..depends where you want to place the v1 ...I keep my v1 in the vette and use the escort 9500ix tight up and against mirror body using the invisicord
Had it wired as above, the only "issue," if even is one, is that it's always drawing power and won't turn off, even if the car if completely off. Will leaving the V1 "on" be able to drain the battery if left on overnight?
That's why I selected that power source as I don't want it starting every time I start the car. Mine has been fine staying on all the time as it takes very little power..I even have my camera connected there...you won't have any issues...if you prefer I'm sure there is some switched power up there,,you just gotta find it...cheers
pics again
push in here..don't pry
![](http://gpchase.zenfolio.com/img/s10/v99/p1981122264-6.jpg)
invisicord from...invisicord
![](http://gpchase.zenfolio.com/img/s10/v107/p2088214681-4.jpg)
the green and pink...slide tabs into plug to connect to power/ground
![](http://gpchase.zenfolio.com/img/s10/v107/p1891958198-6.jpg)
![](http://gpchase.zenfolio.com/img/s9/v86/p2124008398-6.jpg)
chase wire forward to detector behind roof liner and out at windshield
![](http://gpchase.zenfolio.com/img/s8/v79/p2141396968-4.jpg)
One more
Where did you get this blue bar? And what will be good instad of it? Screwdriver?
And what is the difference in this picture? I need like phone cord connector for V1
Sorry..take some initiative..auto upholstery tools..and invisicord will work for both V1 and Escort
Yup..since you're behind the roof liner already I used a hacksaw blade (nice and flat) and modestly pryed the headliner away at the windshield to feed the RJ connector thru...I have the two devices feeding off the same source wires and they stay on constantly as I don't want all the booting noises at each start..the ML battery at 850 CA has plenty to sustain these drains which are very minimal...milli volts
