Windhield Washer fluid additive
Old Dec 14, 2013 | 12:10 PM
14MLBT's Avatar
2014 ML350 Bluetec
Called MB dealership and asked if they have any lower temp additive for my windshield washer fluid because I'm going up north. They can't order it! BS... Anyway, the tech said I could use any. What would you guys recommend?
Sent from my iPhone using IB AutoGroup
Old Dec 14, 2013 | 12:23 PM
Shrdlu's Avatar
2018 GLE 43 SUV
This company makes excellent car-care products.
http://www.1z-usa.com/einszett_Anti-...her_Fluid.html
Old Dec 14, 2013 | 02:23 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
I'm curious as to the heated washer fluid system..can't find anything in manual pertaining to this..do I have it and how/when is it activated ?
Old Dec 14, 2013 | 05:09 PM
Chasvs's Avatar
ML350 Bluetec
Autozone!
Here's a good one! http://www.autozone.com/autozone/acc...er=332611_0_0_
Old Dec 14, 2013 | 07:20 PM
Phil.mount's Avatar
2006 ML 350 sold, 2014 Bluetec "Rudy"
Nanook, not sure about Canada, but in US heated washer fluid is an option, I ordered it on my ML which is in transit. All my older Mercedes had this as standard, the 2006 ML did not so I made sure my new one did. It is a spc code here.
Old Dec 14, 2013 | 07:58 PM
Phil.mount's Avatar
The past systems have the coolant hoses run in a coil inside the fluid "bottle" to keep it heated. There is a thermostat that determines if the fluid goes through it or by passed in warm weather. About all I know but I do know it works!
Old Dec 14, 2013 | 10:53 PM
Nanook's Avatar
Interesting function..I'll have to give it a spray tomorrow and see if it's heated/warm or otherwise..tks Phil
Old Dec 15, 2013 | 08:18 AM
14MLBT's Avatar
2014 ML350 Bluetec
Originally Posted by Chasvs
Thanks! We have Autozone everywhere here! I hope they have it....
Old Dec 15, 2013 | 10:24 PM
fabbrisd1's Avatar
A gaggle of MB's
That Orange stuff is sh*t...
Old Dec 16, 2013 | 11:34 PM
marcanders's Avatar
2021 GLE AMG 63S, 2022 GLC, and 2013 ML350 4Matic
I get the blue stuff for $2 or less a gallon that is rated for -20 degrees Fahrenheit and never have had a problem in any of my cars, Mercedes or not. Don't know about heated washer fluid but never had a problem with the -20 stuff and it got down to -10 about two weeks ago here in Colorado.
Old Dec 19, 2013 | 12:27 AM
14MLBT's Avatar
2014 ML350 Bluetec
The only place I found is at AAFES. I think it was about $3 and it's rated up to -20*
Old Dec 19, 2013 | 02:59 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
I use any fluid that's rated to -35F or colder if you can find it. Anything less freezes in my non heated headlamp washers, even at +20F.
For what it's worth, MB sells something called "Winter Fit", but I have yet to actually see it at a dealer or anywhere.
Old Dec 19, 2013 | 03:27 PM
pcsgrp's Avatar
E350 4-Matic, GLE350, Harley Davidson Electra Glide
Walmart has the rain-x I picked some up today for $2.77. I have also seen some other stuff up in Canada that was good for -35deg F in a Costco and t was very inexpensive. I usually pick up a case of it when I go north.
Old Dec 19, 2013 | 10:21 PM
14MLBT's Avatar
2014 ML350 Bluetec
Originally Posted by dgiturbo
I use any fluid that's rated to -35F or colder if you can find it. Anything less freezes in my non heated headlamp washers, even at +20F. For what it's worth, MB sells something called "Winter Fit", but I have yet to actually see it at a dealer or anywhere.
Yeah dealership had to special order it. We live in the dessert and it barely snows in El Paso, TX. Going to a road trip to Chicago then Canada...
Old Dec 27, 2013 | 11:22 PM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
I use VW/Audi fluid part no G052166M2, which is rated to -70C. This is probably far below northern Canada needs.
To reduce the cost I water it down, as my minimum is about -15C.
Old Dec 27, 2013 | 11:25 PM
14MLBT's Avatar
2014 ML350 Bluetec
I should've not dump my old one out because it hasn't even reached 15*F here at Brampton. When I get back to TX I'll put the MB stuff again.
Old Dec 29, 2013 | 04:53 PM
GoldFeather's Avatar
2005 Honda S2000, 2013 ML350 BlueTEC
The owner's manual states "Only use washer fluid that is suitable for plastic lamp lenses, e.g. MB SummerFit or MB WinterFit. Unsuitable washer fluid could damage the plastic lenses of the headlamps." I've never seen any of the auto store fluids labeled saying that they are safe for plastic lenses. Has anyone checked for this?
Old Jan 1, 2014 | 09:47 AM
Kevd47's Avatar
ML350
This concerns me as well, as I have a '13 that has the headlamp washers in the front bumper. (I believe these were removed mysteriously for '14, in the US models at least) I plan to keep the car for several years, and don't want to take any chances with the $2600 a piece bi-xenon fixtures. Saw that $ figure in a recent post on here.
I have also looked and have not found any locally on the shelf that says it's ok for plastic lenses. The dealership actually gave me a gallon of stuff that's your typical off-the-shelf -20F methanol mix, when I went in there a few weeks back (it was "free"). I didn't pursue the MB WinterFit route with them, and will use that gallon in my wife's car.
So far, I have ordered Einszett's winter mix from Amazon, and plan to use their summer mix as well.
Old Jan 1, 2014 | 10:57 AM
Thanks for the Einszett's recommendation -- it is now in my wish list given that it cites safe for use on all surfaces, including plastic lenses.
Old Jan 23, 2014 | 02:40 PM
DR2000's Avatar
2014 ML350 BlueTEC
Does anyone know what the size of the washer fluid tank is? I looked at the manual and can't find the information. I just added 1g of Rain-X and it looks like it could have taken much more.
Old Jan 26, 2014 | 07:02 AM
Kevd47's Avatar
ML350
5.5 U.S. quarts for anything other than ML63, which has even more capacity.
