RPM at 75 mph
Old Dec 17, 2013 | 07:52 PM
HAILERS2's Avatar
Presently 19 S560 SEDAN, 2014 XK, SOLD GLE 450e
RPM at 75 mph
I'm interested in the rpm of a ML350 BLUE TEC ata 75 mph. Thank you.
I have one being delivered in Feb of '14 and plan to travel on Interstates a lot and want to compare the rpms at 75mph to the torque curve of the engine.
Old Dec 19, 2013 | 08:26 AM
Chasvs's Avatar
ML350 Bluetec
I'll see if I can get that on my way to work this afternoon. Will post tonight if no one else has it before then.
Old Dec 19, 2013 | 12:25 PM
HAILERS2's Avatar
Thank you. I'm trying to figure out how much grunt is left after 75mph for passing. I test drove one up to 100 with the salesman in it and it seemed to pull pretty good up to that speed.
Old Dec 19, 2013 | 02:19 PM
Chasvs's Avatar
ML350 Bluetec
Looks like it was around 2075RPM Wasn't quite half way between 2 and the first dash (2200RPM). It was a short run at 75 so I'm not sure if I was still accelerating or not which would make a difference. I'll check again on the way home if I can. The speed limit is only 65 and there's some construction on my route, so cruising at 75 isn't always possible.
Old Dec 19, 2013 | 04:11 PM
HAILERS2's Avatar
Thank you Chasevs. That satisfies my inquiry.
Old Dec 19, 2013 | 08:40 PM
HAILERS2's Avatar
http://www.caranddriver.com/comparis...e-specs-page-7
I found this page out of Car and Driver and on one page it shows the mph per 1000 rpm in each gear. In 7th gear it seems to tell me I'd be doing 35.7 mph for each 1000 revs.
