2014 ML350 gear indicator
Old 04-19-2014, 09:51 PM
xavier_newMB's Avatar
ML350
First off extremely excited drove home my first MB home a few days ago. Still in the middle of figuring out all the bells and whistles.
One thing I noticed that was bit strange is the gear indicator behavior on dashboard display. We(wife and me) clearly remembered during test drive and the way home the shift was in Auto so dashboard shows "D" all the time. However, the next day when we drove out the gear indicator display changes as the gear changes, ie, it displays "D1", "D2"...."D7" etc depending on apparently the actual gear the car is actually in. So suddenly instead of stationary "D" displayed all the time, the gear indicator actually changes reflecting the gear the car is in.
I am wondering whether anybody else notice this? is this normal? how to understand the behavior change?
Appreciate your time!
Xavier
Old 04-19-2014, 10:00 PM
SmokinReefer's Avatar
ML350
Normal.... In my month old ML anyway.
Old 04-19-2014, 11:52 PM
mellow sparky's Avatar
ML350
By design ... if you decide to take-over shifting with the paddles, you want to know what gear the car is in.
Old 04-20-2014, 06:43 AM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
Mine only shows the gear number when I use the paddle shifters, otherwise I just get "D".
Old 04-20-2014, 07:04 AM
NewtoMBML's Avatar
W166 BT
Mine always shows the gear # as it is automatically shifting (D1, etc) even though I have never touched the paddle shifters...
Old 04-20-2014, 09:57 AM
GregGebhardt's Avatar
2014 ML350 BlueTec
Mine also show which gear it is in at all times.
Old 04-20-2014, 09:58 AM
ML350
I failed to mention my 2010 ML only shows the numbers when I use the paddles. Must be a newer vehicle thing
Old 04-20-2014, 03:47 PM
ML350
Thank you all guys. I didn't touch the shift paddle at all and I never use the manual shift gear mode. It could be new for 2014 model but I was just confused why this didn't happen during test drive and our way home.
Old 04-27-2014, 03:50 AM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
My 2012 ML350 only shows "D" when in Auto mode. But our 2013 A200 shows the actual ratio at all times. Obviously this is the latest upgrade.
Old 05-06-2014, 02:23 AM
BikerBecca's Avatar
W166 ML350 Bluetec
The "D" is displayed when the transmission is in automatic. D+Gear only shows when you've been playing with the flappy paddles. To go back into automatic and stop the display of the gear number press and hold one of the paddles for about 3 seconds and you will see it return to just "D." You should also notice smoother shifting.
Yes, when in "manual" mode the transmission will still shift so you don't blow it up but if you're not going to be playing with the flappy paddles then you should return it to automatic.
Old 05-06-2014, 06:15 AM
2014 ML350 BlueTec
It will also return to full automatic after a short period of time of NOT using the paddles.
Old 05-06-2014, 06:33 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
Mine still shows D and which gear it's in - all the time, paddles or no paddles.
Old 05-06-2014, 07:40 AM
2014 ML350 BlueTec
SO does mine. I am simply explaining that after so many seconds of non-use of the paddles, the ML will default back to full auto.
Old 05-06-2014, 09:19 AM
BikerBecca's Avatar
W166 ML350 Bluetec
You just totally contradicted yourself.
Old 05-06-2014, 09:32 AM
NewtoMBML's Avatar
W166 BT
I tested mine today (2014 bluetec) and if you flick the paddles into manual it will list the gear number only in the square where D was and an M for manual mode shows up on the right side of the gear number (to the right of the box). But otherwise when you go back to automatic the D1, D2, etc will always show up in the box when driving. Must be a new thing for the 2014
Old 05-06-2014, 12:11 PM
Ben_K's Avatar
C43 Cabriolet, GLC 63
In automatic mode, my ML actually shows what gear it is in. If I shift with the paddles, an "m" shows up just right of the gear indicator. Without paddle usage, the "m" will go out. I suspect this is when it is going back into automatic mode.
Old 05-06-2014, 12:54 PM
2014 ML350 BlueTec
I stand corrected. I mis-read Dutch's post.
I noticed something else when I DO use the paddles. When accelerating in like 3rd gear with the paddles, I notice a 4 with a green arrow pointing up, I guess suggesting that I move into a higher gear. Anyone else see this green indication?
Old 05-06-2014, 01:32 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
A running change was made whereby the gear is shown, regardless of whether you are manually shifting or not. The car will also automatically shift back into "auto" mode after a period of time in "manual" mode.
Quick Reply: 2014 ML350 gear indicator
