First oil change at 5K?? Would you?
Old May 3, 2014 | 01:22 PM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
Originally Posted by frtdog
I may have missed this but what kind of a time period are we looking at. Has it been a year? My annual milage is only around 6K and the oil change is changed on time not milage.
You're not driving it enough! Get out there and enjoy it.
Old May 3, 2014 | 06:00 PM
pcsgrp's Avatar
E350 4-Matic, GLE350, Harley Davidson Electra Glide
I think your right, I guess in the northwest they don't drive all that much. I thought I did a lot of driving in NJ but when I go to Florida it really adds up.
Old May 3, 2014 | 07:00 PM
frtdog's Avatar
2020 GLE 450
The challenge is from a medical point of view. We just can't get out and drive around like we used to.
Old May 4, 2014 | 10:02 AM
cohenmd86's Avatar
12' S350 blutec, 13'ML550, 2011 ml350, 2015 Jeep Grand Cherokee Summit
Originally Posted by GregGebhardt
I know this has been covered before but I will be nearing my 5k on the ODO in a few weeks and wondered if you would have the oil changed. I know it says 10K but thought I would get everyone's opinion.
I will be taking it in for a tire balance and rotation at the same time.
My man, have a 2012 s350, an 13 ml550, a 12 vw tdi toureag......go the 10k at the bare minimum, I push all of mine past and go sometimes 13.5-15k miles it doesn't even have any affect on the motor....one of my guys would run his bmw 335 up to 20k in-between each oil change, do not waste your time or money...I drive hard and the mechanics all say my oil looks no blacker or worse at 8k, 10k, or 15k......besides its got a warranty anyways which its very hard to prove if something did go wrong that it was the oils fault.......
Old May 4, 2014 | 12:16 PM
Ben_K's Avatar
C43 Cabriolet, GLC 63
With a 1,000 mile on my ML, I found this thread of great interest. There are several web pages discussing the improvements of oil because of synthetics, and their ability to withstand long term heat breakdown. Being old school of the original 3,000 mile or 3 month changes is is not easy pushing past 5k on changes. I am including the one link below that Mercedes has for tested oils.
http://bevo.mercedes-benz.com/bevolisten/229.1_en.html
I know this debate will continue on.
Old Mar 20, 2021 | 11:10 AM
teksurv's Avatar
2024 EQE 500
If it meets the spec you will be fine. That said, for no logical reason, I'd keep using what you have been given the longevity.
Old Mar 21, 2021 | 10:17 AM
  #32
mikapen's Avatar
Well you have a warranty as long as you can prove that you performed the required maintenance on time.
If not, it's the owner's fault, not the oil's.
The color of the oil as reported by a mechanic is irrelevant, especially with a diesel.
Old Mar 21, 2021 | 01:38 PM
  #33
Etienne Lau's Avatar
Ml350 bluetec
Color of oil is not relevant even on gasoline engines, not just diesel engines. Unless you have sent the oil off for analysis, drawing conclusions about changing the oil at 500, 1000, 3000, 5000 miles is meaningless as well. It's all conjecture that changing oil sooner is better than later.
Old Mar 21, 2021 | 02:44 PM
  #34
mikapen's Avatar
Especially when "color" is "as reported by mechanic." Time to look for a new mechanic.
