Check Brake Pad Wear - Message
Old Jun 28, 2015 | 04:15 PM
Rico ML350's Avatar
ML350
Got this message today on my 2012. Car has 34K and all 4 brake pads are way thicker than the backing plate. In fact the pads are thicker than on my wife's 2010 with 50K.
Bad sensor maybe, or is the message based on something else?
Thanks... Rico...
Old Jun 29, 2015 | 06:19 PM
fabbrisd1's Avatar
A gaggle of MB's
Sure,,, get your brakes checked for specific thickness... keep the beat !
Old Jul 1, 2015 | 09:27 AM
rtw_travel's Avatar
2012 ML350 BT, 1998 BMW 540i/6
I'm still learning about the ml350, but the wear sensors on my bmw have broken at least once when the pads were still fine.
I assume MB uses a similar system as bmw. Look for a single small gauge wire clipped onto the caliper. There may be only two sensors for the car: one on one wheel in the front, and one on the opposite wheel in the back. When the clip wears down (as the brakes wear), the wire touches the metal, and you get the warning message.
If it gets knocked loose by a rock or perhaps dislodged when you changed tires, then you'll get the warning. Simply plug it back in and it should be fine if the pad thickness is fine. The warning light should reset itself after a few drive cycles after plugging it back in if the sensor is not broken.
Old Jul 1, 2015 | 07:04 PM
Rico ML350's Avatar
ML350
I too am very familiar with the BMW system!
The light has gone out and I changed nothing. I knew it was an error as the pads have loads of life left.
Thanks for your input.
Old Jul 2, 2015 | 01:38 PM
Dallas5Star's Avatar
2014 E350 Sport
On my 2012 ML350, which I've had since new, I need new pads every 35k miles. I currently have 75k. I've learned that the sensors measure the inner pad. Can you see the thickness on your inner pads? On my 2nd set of rear pads, the dealership must have done a poor job cause the sensor came on after 20k miles even though the outer pads had like 7mm, the inner were down to 2mm. I've had my breaks worked on by an independent and now use ceramic pads and I have even brake wear and no dust with great stopping power.
Old Jul 7, 2015 | 06:57 PM
Rico ML350's Avatar
ML350
It was the inner pads. Just replaced with ceramic pads and new rotors all around for $435. Indy price obviously.
Rico...
Old Oct 9, 2015 | 07:45 PM
Mlfremont's Avatar
Ml350 4matic
Check brake pad wear on a new Ml
I have only 2400 miles on my 2015 Ml350 and got this message. Taking it to the delear see what is causing this problem. Will update on the outcome.
Old Jan 11, 2018 | 12:34 PM
noelarni's Avatar
GLK250 2015
I replaced ALL break pads front and rear including sensors but I'm still getting "Check break pad wear message"
GLK-250 2015
Old Feb 13, 2018 | 06:25 AM
sack5000's Avatar
2015 AMG C63 S
GLK-250 2015
thanks for your input, the dealer should reset your service message especially when replacing all pads. I have same issue with the light coming on when pads shouldn't be worn much at all.
Old Feb 15, 2018 | 10:08 AM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
I just had my 40k "B" service done and I was told my pads are only 30% worn.
Old Feb 15, 2018 | 11:23 AM
noelarni's Avatar
GLK250 2015
You still have at least 10 to 15K more to get replaced.
Here's the link on which brake pad to choose from;
https://www.bridgestonetire.com/trea...lic-brake-pads
Old Feb 15, 2018 | 12:22 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
GLK-250 2015
WRONG FORUM. This is W166 ML/GLE forum, not the GLK or C63 one.
Old Feb 15, 2018 | 01:14 PM
DanD.'s Avatar
2018 GLC 4MATIC
Front or Rear or All?
I had to replace my rears at 37K, front are still original. Car has 73K now and rears still good.
Old Aug 15, 2018 | 06:43 PM
Sandmansc's Avatar
c250 w204
14 e350
Same. Check brake pad wear. Replaced pads. Still have warning message. ??
