really anoying squeaking driver seat
Can you post what the dealer found and what parts are on order? The dealer we are using simply keeps on adding more felt tape to parts inside the seat. Thanks in advance for any info you can provide.
Thanks!
Thanks again for the note.
After swearing and manipulating the seat every which way, and searching forums and YouTube etc I managed to fix it myself with some lubricant spray and 30 minutes of disassembly and re-assembly..allen keys, socket set and a torx screw drive are required. Sorry, can't remember the sizes, was a while ago.
Take off the three plastic panels on the door side of driver's seat and locate the one and only large silver nut on the inside and underside of the seat frame closest to the door. You'll need to put your seat up high and stick your head under to see it. Loosen it slightly, give it, and the surrounding area, a light spray and re-tighten.
I took pics when I did it so when I find them I'll post them. Haven't had a single squeak since.
<edit> found pics - note this is a right hand drive ML 400.
Step 1, set the seat up as high as you can.
Start removing panels
Pay attention to how this part is fitted as you remove it, it's tricky to get back on, particularly where the seat belt is, so be patient.
Just check to see if you can locate the nut in the last photo before you remove this part, you may not have to remove it if you can access the nut to loosen it.
I can't remember if I needed to remove this to access the nut or I had just removed it as part of my trouble shooting search before i located the source of the squeak. It was a fair while ago.
Need to look under where the nozzle is pointing to locate the nut and bracket(s)
This is the offending nut . The two brackets under it are the source of the squeak.
Last edited by MattyC; Aug 16, 2019 at 12:48 AM. Reason: update to instructions, added pics.
