Bought a 2013 ML350 in Feburary. It had the OEM 19" wheels on it. I purchased a set of OEM 20" AMG wheels for it with new tires and I'm wondering about TPMS...
I've heard that all MB cars here in Canada do not have TPMS which doesn't sounds right to me. Is this true?
Since I'll leave my winter tires on the 19s, I guess the question is: will I need to buy 4 TPMS sensors for my 20" summer kit?
I believe that the TPMS is in the abs system, in Cdn ML's
Ask a dealer for sure
We have tpms..at least mine does..
Diabolis
close
- Join DateJan 2013
- LocationThe Great White North
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Liked:811 Times in 554 Posts
In Canada the ML63 has discrete TPMS sensors, but the rest of the W166 ML line AFAIK uses the ABS sensors for the TPMS functionality. The easiest way to find out is to select the tire pressure information menu in the car - if you can see INDIVIDUAL tire pressures in PSI for each wheel, then you need discrete TPMS sensors and furthermore need to call a dealership with your VIN so they can give you the exact part numbers. If it only says that the system is operational and gives you the option to (re)set the current tire pressures as normal, then you don't need anything else.
the ML blutecs do not have the TPMS here in canada.
I have a 2014 ML with the 20" sports OEM wheel, i took those off after 2 months, and I swapped to a 22" wheel (no TPMS)
and for winter I have 19" Replica OEM... no TPMS
no issues at all
no issues at all
Thanks for the answers guys. Doesn't look like I have TPMS either.
no issues at all
Manny can you post a pic of your ride with the 22" rims?Originally Posted by MannyS430
the ML blutecs do not have the TPMS here in canada.I have a 2014 ML with the 20" sports OEM wheel, i took those off after 2 months, and I swapped to a 22" wheel (no TPMS)
no issues at all
Wrong post.
Explorewhere did you purchase those rims here in canada? does it have a blank AMG window? what are the specs of the rims (width and offset?) and while you are at it specs of the tires please.
