2013 ML350 Bluetec Mass air flow error code
Where were these sensors?? Are you sure that there are two that's very weird. If you search what the MAF part looks like for the ML its round so i think you cleaned the Air Mass Sensor instead of the Mass Air Flow Sensor.
Did it look like this?
I have the exact same issue, same codes and kind of hear a hissing sound as well. Could you tell me which is the boost hose so that I can inspect it? Thank you in advance for your time.
P010D
P010A
P010C
P00AA
P00AD
Mercedes only sells the complete two sensor assembly for around $800 PN A6420901642. Also, I could not find a used on in the US but was able to find a used one on ebay Germany for $250 including shipping. Since the unit has two sensors I will end up with a spare one just in case I have another one fail. Hope this helps someone.
Did you separate on the sensor side of the rubber boot (A in the photo below) or the other side (B), toward the center?
Looks like you had codes for both temp sensor and MAF (and yes I know they are the same assembly) as I have. I am kind of surprised that one part of the component doesn't fail first while the other keeps working.
Here are the codes I am getting - this is on my GL350 bluetec 2013
p0110 IAT
p0113 IAT high
161700 The signal of component 'B2/7b1 (Right intake air temperature sensor)' is implausible.
161800 The signal of component 'B2/7b1 (Right intake air temperature sensor)' is implausible.
168D00 This function is not yet supported by the control unit.
p0102 101500 The lower limit value of component 'B2/7 (Right hot film mass air flow sensor)' has been reached. [or EGR cooler switchover valve overtemp]
p0100 100D00 The lower limit value of component 'B2/7 (Right hot film mass air flow sensor)' has been reached.
If you are unsure on how this unit is put together, as I was, try pulling the rubber section out of the ring first. Once that is out it should be more clear. It is very easy to break the ring so take your time.
Hope this helps
Some Humor
trying to clean up oil gunk from an old turbo oil leak in this tube/section.
tried tugging at those rubber boots to see if something was coming apart where section A and B meet, but nothing (was gentle to avoid breaking anything).
Any more tips/tricks for separating A from B? was a heat gun required to soften things up? use of a hook/pick set maybe to get under the shiny hard plastic ring (is that the ring holding the flange that you are speaking about above to not break?)
also how to remove those sensors? just heat with a heat gun and pull? if heated to pull out, how did they stay in after trying to put them back, any glue required?
i did my best to clean the area with CRC MAF sensor kleen, and plenty of black crud poured out, but i can see that it is still pretty dirty in there and i would really like to take it apart and clean it nicely.
any videos online/youtube showing how to take it all apart?
horribly designed piece
When I ordered a used unit from LKQ Potomac German parts they came like you see there except they both had the rings. MAKE SURE TO ASK FOR THE WHOLE UNIT OR AT LEAST MAKE SURE THEY INCUDE THE RINGS.
From what I recall, you should be able to pull the rubber boot out from the ring. Just kind of pinch it and try to pull it inwards and then out. Try to get one little section out and then the rest will follow. Again DON'T DO IT if your unit is functioning. Treat this thing with kid gloves because it is expensive to replace if you screw some little part up. I over-torqued the hose clamp on the turbo and snapped it, then cracked the plastic and broke off an alignment pin when tying to get a standard hose clamp from the auto parts store to work (standard hose clamps are too wide to use here).... if it had broke much more I would have ended up having to source another unit!
Another previous post was talking about needing to reprogram/relearn after swapping one of these. My issues were solved without doing that but I don't know if perhaps it wasn't as efficient or something. I eventually asked an indy mechanic to do the reset/relearn procedure. My *guess* is that the car will adapt itself over time and the reset just gets it back to factory setting and maybe it relearns over time from there. Or maybe it kicks in a faster learning procedure for some period of time. That is all complete wild guessing. In any case, don't spend thousands of dollars on equipment just go to an independent mechanic and offer to pay them to reset it. I waited until I took my car in for something else and asked if they would just do that as well and I did offer to pay but they didn't charge me since I was doing other work.
Could you pls elaborate a little more on the MB star from Alibaba for $9?. What's exactly that?
Hope this helps
Hi there could you elaborate a little on the MB star from Alibaba for $9... What it is exactly that? Thanks so much for your help
Some Humor
https://www.youtube.com/watch?v=Fk-da3O8mHQ
2013 ML 350
2015 ML 350BT same issue. You can buy a reman from most Merchants dealers is the US for around $450. I took mine off and sprayed it twice with MAF cleaner. Cleaned all contacts but no luck. Engine light still on
I am going to be selling my cloned MBstar/Xentry setup with a tough book. Cost me $900. Not sure what I will ask but I sold the car so I have a lot of stuff.
