ML350 Wheels'n Tires
Old Aug 2, 2021 | 08:49 AM
  #51
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by myozin
I’m getting
front 275/45/21
rear 315/40/21 (2021 GLE53 AMG)
pls advise me, what do u think of rear one size
They will not fit correctly. While I think 2" taller diameter tires will clear, there will be a significant rear poke (due to rear wheel's width/offset and 315 tire) and more importantly these V167 wheels are made to be used with different bolts (15x1.25 instead of W166's 14x1.5).
Old Dec 11, 2021 | 08:10 PM
  #52
Doubleredrolex's Avatar
2014 ML550 AMG package
hello, I’m getting 21”rims on my 2015 ML350 too, how is ur rims on ML350 so far ? Do u have any problems? Are they Staggered rims or all around?
I’m getting
front 275/45/21
that’s a huge oversized tire compared to stock diameter on a w166. That’s bigger than a GL550 tire. ML63 runs a 295/35r21. Going to a 45 series is a much taller tire and it might not even fit in the wheel wells. Post pics if you make it work.
Old Feb 6, 2022 | 03:45 AM
  #53
JonL's Avatar
2012 ML350 w166
Wheels.
Originally Posted by peter2772000
Ok so decided on the following;
Pirelli P Zero Rosso in 295/40R20. On a 20" x 10.5" rim the tire specs are as follows.
- Section width, 12"
- Tread width, 10.6"
- Height, 29.3" measured on a 10.5", so in my case I'm guessing about 29.6" which I can live with.
Still haven't found a rim in a 20" x 10" size with an offset around 56mm. Life would be perfect if I found such a rim with a 66.6mm bore to boot, though I have run hub-centric rings before with no issues. I don't think I'll have to do the staggered deal.
I have AMG replicas for sale 20x10 of set 45
I have the center caps as well.
Old Mar 27, 2022 | 04:41 PM
  #54
larryking63's Avatar
2015 ML63
ML63 W166 RIM CONVERSION FROM '21' to '22' Brabus
Hey guys,
Need a little help.. im doing a little personal project for converting my ml63 to B63 BRABUS so i ordered brabus monoblock 22inch rims for the car and the specs are as follows:
22 x 10 ET 51
  • however what i cant seem to figure out is the tire size i am stuck and cant figure it out brabus recommended 275/35/r22 but i feel the 35 is too narrow and want a perfect look below are pictures of the car and the rim please advise
Old Mar 27, 2022 | 04:47 PM
  #55
2015 ML63
Here are images
This is my car with gloss black 21inch 295/35/r22 project status so far : Stage 1 tune 650hp 850NM Weistec cold air intakes NGK One step colder spark plugs
the car i want it to look like
Old Mar 27, 2022 | 05:24 PM
  #56
MBJIMBO's Avatar
2018 E300 Sport:Current 2015 Mercedes Benz C300 Sport- Gone.
That is not a real Brabus wheel. That is a copy knock off wheel, so whatever specs they are providing, they are not per Brabus.
Old Mar 27, 2022 | 06:01 PM
  #57
MBJIMBO's Avatar
Brabus does not make the Monobloc F wheel in a 22" cast wheel. They only make that wheel in a 23" Forged version for the ML/GLE platform.
The cast versions of the F only go to 20", and I don't believe they made a 20 inch F for the suv platforms.
The Brabus Monobloc R comes in a cast 22x10 et65 that then requires the Brabus Spacer/Adapter system to the correct matching vehicle offset.
Old Mar 27, 2022 | 11:08 PM
  #58
A 275/35r22 is a slightly taller tire than OEM. It’s a GLE size tire. But it will work on the ML. I wouldn’t go bigger than that. If you are worried about it being too narrow then go to a 295 wide.
Old Mar 28, 2022 | 01:04 AM
  #59
2015 ML63
hey thanks for the advice but i am guessing you just did not know brabus had the 22x10 inch option for ML63 they said the waiting time would be 3 months aswell.
Old Mar 28, 2022 | 01:10 AM
  #60
2015 ML63
thanks alot so by narrow i meant the profile'35' i saw a '40' and my its huge.. theres a couple of potholes around my work place and the last thing i want is loosing a tire..
Old Mar 28, 2022 | 01:17 AM
  #61
2015 ML63
Also the spacers come in if you are purchasing the widestar body kit other than that they give you offset options too
like this one for example..
Old Mar 28, 2022 | 04:27 AM
  #62
yeah I wouldnt want to hit any big potholes with a 35 series although it’s not too bad. I’m in western canada and the roads are pretty good here so I’ve been ok so far.
This is mine on 21x10 AMG wheels and 295/35r21 tires.
Old Mar 28, 2022 | 03:55 PM
  #63
MBJIMBO's Avatar
Not sure who supplied you that chart, but I am going to guess it is the dealer selling you that wheel that is NOT a Brabus TUV approved or Brabus manufactured wheel in a 22x10.0.
I worked directly for Brabus dating back to 1999 when they opened their first US operation, and I worked for them on and off up to 2012, and in 2013 after opening my own company I became a Dealer/Distributor for their products.
I can assure you that the wheel you are being presented is NOT a Genuine Brabus wheel or application, so you should take caution as any failure of the wheel is not the responsibility of Brabus, and it is a Tarnish to their brand and name to promote this application as it is 100% not their genuine wheel. The Monobloc F Platinum wheel is a Forged wheel that is only available in a 21, and 23" application.
Also, it is a shame that someone is trying to sell you something under the premise that it is a genuine part that comes from a Premium brand, and it is in fact not at all worthy of the Premium price tag or Brand recognition.
Just letting you know. If you go to BRABUS.DE and go into Tuning, go to the GLE 167 Platform as that is the only current chassis similar to the ML and you will see the wheel applications listed, and that wheel you are claiming to be a Brabus is no where on their site.
That vehicle you posted in their showroom is fit with the Brabus Monobloc G, another Platinum Edition forged wheel, and that wheel does in fact come in a 22x10.0, ET65, that is then fit with the Brabus Spacer Adapter kit like all Brabus wheels that accommodates the offset of each application, and also uses wider bolt on adapters for Wide Star applications.
Ask your wheel supplier for the wheel part number, then call Brabus direct and ask them to confirm that part in their product lineup and I guarantee you that you will discover it is not a Brabus wheel. If you want a Brabus 22x10, the offer the G, which is a forged wheel, but they do also offer the Mono R in a 22x10 cast version that is more affordable, but still $1,895.00 per wheel. If that wheel that is a F copy is priced anything lower than $1,895.00 each, that is also another indicator that it is a Fake!
I hope this helps.
Old Mar 28, 2022 | 11:37 PM
  #64
2015 ML63
I hope this helps.
Hey you're actually right come to think of it the supplier has done a couple of conversions on cars and they say they are a verified brabus supplier and the price is $2,300 each however you caught my attention on having worked with brabus maybe you might enlighten me with a thing or two i bought a 2017 g63 with the brabus exhaust system was told it was remapped from brabus has the stickers and everything.. also to open the flaps i have to use the button on my steering wheel but its fuel consumption is out of this world could it be the exhaust system???
Old Mar 28, 2022 | 11:42 PM
  #65
2015 ML63
This is mine on 21x10 AMG wheels and 295/35r21 tires. this looks gooddd although they look more like 22s didn't know the 21 looked this big
i like how yours is sitting low plus the 21s look more like 22s
Old Mar 29, 2022 | 01:18 AM
  #66
thanks that’s -32mm down front and rear with the OBD2 plug in lowering module. I normally have it set to -20mm front and -25mm rear for a more level stance.
Old Mar 29, 2022 | 07:15 AM
  #67
the bad mileage would be due to the remap they did which is an ECU tune. You could flash it back to stock if you want. Not sure how much the Brabus tune changed it though, as the ML63 and GLE63 get horrible mileage to begin with. ML550 is absolutely terrible in town and I can imagine the ML63 is worse.
Old Mar 29, 2022 | 02:23 PM
  #68
2015 ML63
i rate the brabus tune for one thing!!! high end torque from rolling in 3rd gear or second boyyy that gets all fours going crazy 0-60 its not as impressive in the m157
Old Mar 29, 2022 | 08:30 PM
  #69
that’s why you are getting terrible mileage haha. It’s too much fun to play with. I wonder how it compared to the Weistec tune for the M278. The Weistec tune puts out ML into ML63 power ranges.
Old Apr 14, 2022 | 02:36 PM
  #70
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
Finally got my AMG's refinished in Satin Black with CNC Lip 21x10, 295/35/21:
GLE fenders coming soon!
Old Apr 14, 2022 | 07:35 PM
  #71
Looks good. The GLE flares will complete the look.
Old Apr 15, 2022 | 05:38 AM
  #72
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Nice!
