Apple car play- anyone successfully added?
Old May 16, 2017 | 02:27 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
i know that on the 2012-15 models the comand version is older, not that i mind it, much simpler if you ask me, Has anyone been able to successfully mod it on their own? just out of curiosity or does it seem too impossible of a task
Old May 17, 2017 | 06:54 PM
ntwillie1's Avatar
07 TL, 05 350z, 08 MDX
Interested in this as well. Had an e300 the other day w CarPlay and I really liked it.
Old May 21, 2017 | 01:03 PM
lv0212's Avatar
W204
one possibility is to retrofit your comand system from NTG4.5/NTG4.7 to NTG5.0
Old May 22, 2017 | 12:40 PM
drwolf's Avatar
can it be upgraded?
Old Nov 27, 2019 | 12:33 PM
ketanpunde's Avatar
2013 (W166) ML350 Bluetec
I am considering this product: aliexpress.com/item/33000000887.html and installation link:
The motivating factor to go for this product is that it is designed very specifically to integrate with NTG4.5 4.7. You can use the existing round dial/joystick, stg wheel controls, back controls. And because the product is designed so specific the cost over 350 USD is justified considering the R&D cost, and the target audience/customers will buy to modify. I am waiting one more day for black friday deal which will bring down the price to 347 USD.
Old Nov 27, 2019 | 03:07 PM
Don_CA's Avatar
ML 350 Bluetec
That sounds like what I just posted about in another thread https://www.ebay.ca/itm/Fit-For-Merc...t/392309711343
Old Nov 27, 2019 | 04:15 PM
ketanpunde's Avatar
What I posted is for w166 with NTG 4.5 / 4.7
What you have posted is for NTG 5.0 onwards (heads up display)
Old Nov 28, 2019 | 08:19 AM
Don_CA's Avatar
ML 350 Bluetec
I do not know where my link took you, but it is for NTG 4.5 and a W166. I even emailed the seller and they confirmed:
"Yes, friend, this kits is indeed provide both the CarPlay and Android Auto functions in your car. Not only the mirroring. And yes, your car model is indeed supported, but there is just one thing need to be noticed.
As you can see in our description, you need to make sure that you have the Aux option activated under the Audio menu. Otherwise, you won't be able to use this kits normally. If you have already got the Aux option under the Audio menu, then you can just place the order directly. Thanks!"
Old Nov 28, 2019 | 09:18 AM
ketanpunde's Avatar
You are absolutely correct about the product, it is compatible only with Aux option. One more thing I noticed is the apple car play will work only through wired connection. Please correct me if I am wrong.
Because the other product I found on Aliexpress, it allows the car play with bluetooth connection.
Old Nov 28, 2019 | 09:40 AM
Don_CA's Avatar
ML 350 Bluetec
Yes, that is the wired version, they have a wireless one as well. The one you posted requires AUX as well.
Old Nov 28, 2019 | 11:26 AM
ketanpunde's Avatar
Do you have success in installing the ebay - Carlink product in yours?
Old Nov 28, 2019 | 11:33 AM
Don_CA's Avatar
ML 350 Bluetec
No, my thread was asking if anyone had tried anything like it. I cannot find any reliable reviews anywhere.
Old Nov 28, 2019 | 03:57 PM
ketanpunde's Avatar
This is what I have found so far for NTG 4.5/4.7 :
1.Unichip (wireless) - USD 439 (unknown source to buy, still investigating how to buy, the chinese supplier will get back to me as per their business hours)
2.CARTIZAN (wired)- USD 242 (Ebay)
3.Zhoyito-JoyAuto (wireless) - USD 379 (Ali express Black Friday deal USD 346) only on 11/29
I am buying the Joyauto product from Aliexpress. Sounds like a reliable and prompt supplier in terms of service/installation support/warranty.
Old Nov 28, 2019 | 10:21 PM
excal's Avatar
W166
I've been looking into these as well. My only hesitation is that they all seem to use their own microphone, which means finding a place to mount it and the inevitable issues with echo and background noise that Mercedes engineers would have spent time to overcome. If the third party vendors can find a way to intercept the OEM microphone signal this would be a perfect solution.
Old Nov 28, 2019 | 10:38 PM
ketanpunde's Avatar
Agreed 100%. I have bad experince with an aftermarket Audio-Nav double din for my 07 Passat.
Therefore, after careful observation, I noticed that option No. 3 in my list, you can opt to not install the microphone. Result - you will not have the option of "hey Siri"
Let me know what you think.
Old Nov 28, 2019 | 11:03 PM
ketanpunde's Avatar
Unichip this company just quoted 469 USD
