CPA Chiptuning installation ML
Old Oct 21, 2017 | 06:53 PM
sbaer's Avatar
2011 E63 M156 :) - previously: 2016 GLE63 with U21 (missed); 2012 ML550 , ML63 2009 - E550 W212 2010
I used to have a Racechip in my vehicle but their app doesn’t work right and I kept getting a check engine light and when browsing around I noticed CPA Chiptuning now has US based support. I reached out to them and decided to give them a shot. Here are some thoughts. I am no mechanic and the installation took me a while. Basically I ended up removing the air filter boxes for easy access. Since those were out I opened them and was greeted by an old filter. Picture below. Mind you this truck is serviced at MB but that is a discussion for another day.
Wires routed...
​​​​​​Module secured. This seemed like a good place to put it.
I got their Connect system which comes with a gas pedal module and you control both the engine and gas pedal in one. It’s the gadget pictured.
The gas pedal plug was a bit tough to get to but I got it in the end.
I have been running this for a week now and really like it. No phone needed to try and set it up. Just works when starting the engine and somehow the gas pedal uses a wireless link to control the engine module as well.
Power delivery is smooth and now I don’t even care anymore that the 550 does not have a sport button like my old ML63 since the Pedalbox allows me to select different sport modes. Fantastic. I had so many issues with the Racechip app and phone compatibility that using the one adjuster makes this a no brainer.
​​​​​​Here is the old filter… Without words..
Old Nov 5, 2017 | 03:26 AM
johnng117's Avatar
2002 C32 AMG
CPA chiptune screwed up my transmission
CPA chiptune screwed up my transmission after using it for around 6 month.. Be careful...
it doesn't respond well to ignition being on but the engine is off, this situation is sometime when your filling up, you leave the keys in.
Old Nov 5, 2017 | 07:58 AM
sbaer's Avatar
Given that my prior chip caused some issues and this one runs fine I am confident. Still going strong. Maybe you had a wrong version, Euro spec? Installation wrong? They just started selling in the US.
Old Jan 20, 2018 | 12:42 PM
andrell's Avatar
cl600
Please tell me how u got to the MAP sensor on the driver side. I can't get to it at all.
Old Jan 20, 2018 | 01:41 PM
sbaer's Avatar
Mercedes made that one tight and I asked my girlfriend at the time to help me plug it in. She has smaller hands.
