Ideas For Custom Subwoofer Install?
this is the HK logic 7 diagram in the ML350 so this could serve as a guide?
the challenge with these audio installs is I want everything stealth and hidden away. a giant box with two 12" subs and neon lights taking up half my cargo space is definitely not my style
hoping to have everything installed this week.
nchy and clean with no distortion, even when the head unit is turned to 10.
I saw another member here post an install with a large sub facing up and he cut a whole in the deck and put a grill over the speaker, which probably allowed for a couple more inches in depth...It looked pretty wild. I change cars often and take my gear with me, so I prefer not to alter the interior.
2) Run the four tap wires to your Line Output Converter (LOC) speaker/high level inputs
3) Connect the LOC to your amp as usual
Speaker wires provide a signal. The LOC converts it to low-level RCA output; higher end units allow for restoration of lower frequencies (which are generally rolled off by factory head units), remote trigger for amp, and higher voltage levels.
I also recommend keeping your spare; a 0.66cuft sealed box for a 10” sub isn’t that big, and would be very easy to remove if the additional room was required. Personally, I’d rather be able to put on a spare than show off how “clean” my install is or any other concern I can conjure!
1) Tap the rear speaker +/– wires
