rear brake pad / rotor replacement at 24K? What is the cost?
My ML250 (2015) recently had the Check-brakes warning turned on. Took it to the dealer - they just got back with a cost of $787 for rear brake-pad and rotor replacement. The vehicle has 24K miles on it - and has been serviced at the appropriiate intervals. Is it usual to need replacement of rotors and brake pads with such low mileage? Is the cost reasonable?
Sameer
Sameer
I bought pads and installed them by myself.
Dealers always wants to change rotors each time but mine was in good shape and far away from min mark.
Next time I will replace rotors so far I added 40K and still good.
Mine didn't even triggered pad warning sign, but one pad which didn't have sensor attached got paper thin.
I agree all of you, the price is reasonable, but can be cheap if you are using someone other than the dealer.
Anyways - I got quotes from three repair shops all of which specialize in imports / german cars (and good reviews on google / yelp) - and the quotes are interesting - $420, $580 and $720 !! Two of them use Textar parts (which they said were the same ones that MB uses - except these wouldn't be MB labeled) - I forgot to ask the third (and most expensive one). I won't be doing the service at the dealer.
