ML350 cargo area rattle
Old Mar 9, 2020 | 07:28 AM
C280 Sport's Avatar
MB’s of all kinds.
Wow! That is crazy! I had this issue but for me it was the cover that went over the cargo area. Took it out and put it back in. No issues. Hope your issue gets fixed. In the video I could not hear it. Are you 100% sure it comes from inside the car?
Old Mar 10, 2020 | 06:05 PM
Zuffen's Avatar
2002 Ml320, 2012 ML350 & Slk55
The seal runs around the opening, not on the hatch.
It just pulls off.
When refitting it I give it a squeeze to make it fit tighter then just push it on.
This has the rubber that must be eased over the interior trim on it.
Old Aug 22, 2020 | 09:23 PM
Tomhui's Avatar
2016 GLE350 4matic
Originally Posted by CSM
Alright well as you can see I completely disassembled my ML, still can't say with 100% certainty where the noise is coming from, I believe its the shock absorber. I noticed a post in the GLK forums about rear shock noise and how the rubber isolator wears down, thought I had found the problem. Removed the top of my ML shock and found the ML's don't have a rubber isolator its metal on metal with a tiny o-ring between the plate and body. I added a 1/4 inch crushproof rubber washer, no change, I took a video after I added the washers below. I also removed all the covers from underneath the car, gas tank skid, DPF skid, wheel liners. Im at a loss, only reason I still believe its the shock is the noise is so sensitive to any bump (and there wasn't much left on the car to rattle), my tires had been at 28PSI and I aired up to 45PSI for my trip home and this made the noise much more noticeable .... Anyone have any suggestions??
​​​​​​https://youtu.be/T3dqMCBiMhE
Hey there, I have a 2016 W166 now called the GLE350. I have noticed this noise for the past year and it has been driving me crazy. I can almost guarantee you the rattling is coming from this panel where the rear seat belt goes into. I have not removed it for fear of damaging the panel. But if you would like to try, I assure you the noise of coming from this damn area! You can knock / tap on the panel and hear the rattle. It may be coming from both sides as well. I hear it rattle whenever I go over bumps on the road. Very disappointing quality for a luxury brand.
Old Aug 24, 2020 | 06:24 PM
Lanzz's Avatar
2024 E450 AT Wagon, 2024 EQS450+ / Had: 2021 E350, 2019 E300, 2021 + 20 GLE350, 2019 E450 Wagon(s)
Never solved a similar issue with my 2019 E450 wagon - traded it out of sheer frustration. I agree with Tomhui above - I always thought it was up in that area around the top anchor of the rear seatbelt.
Old Aug 24, 2020 | 07:15 PM
Art100's Avatar
W166
Hi, It maybe seatbelt unit that rattles like here:
Try fasten the rear left seatbelt and test drive to see any differences in rattle.
Old Nov 11, 2023 | 08:42 AM
kkarb's Avatar
w164
Hello All,
This is my second ML350 Bluetec (both 2014s). Both have had this rattle in the cargo area I can't seem to track down, I believe it is inside the car not suspension related. I have searched and searched other posts to no avail, Its not the cargo shade (I don't have one) the tile laying across the seat backs is something another post had referenced. I ran a video both under the car and inside, can't replicate the sound under the car. Inside the Go-pro slightly picks up the sound, best way I can describe is a rattling plastic canister? Its hard to pick up the sound in the video it almost just sounds like road noise, the best example is 1:02-1:10 in the video. Any ideas??
https://youtu.be/ZPY07sfsom0
Did you solve it?? In have excact same at my w166 -14 mod.. Not possible for me to locate😇
Old Nov 12, 2023 | 06:58 PM
  #32
CSM's Avatar
CSM
14 G550
Hey, no I never did solve this. Just learned to live with it. I sold the car a few years ago. I’m almost wondering looking back if it was drive shaft related. I disconnected seat belts, rear shocks, everything possible to isolate the noise and never found it.
Old Nov 13, 2023 | 07:43 AM
  #33
kkarb's Avatar
w164
Strange.. I also has new shock absorbers, no differense. I suspected the main sway bar bushings (rear). Today i disconected to sway bar links, and drove a trip whith the main sway bar free from car... But no difference. So its not them eigther. This is driving me nuts.
