Replace headlight light bulbs with LED
I would like to replace the original halogen headlight light bulbs with LED light bulbs...
Can someone recommend the right brand and size... it seems like there are so many options. There are LED's with fans and fanless... etc...
I've also read some comments about not being able to fit the LED because they are larger than the regular stuff. Please help me out.
P.S.
Should I stick with HID's? is it better?
P.S.
Best piece of advice -- don't go in through top of engine, remove access panel in fender lining -- turn wheel all the way to left or right and you'll see the small panel where you can easily get up to the low beam.
I give specific parts to buy. Instaling isn't hard.
I've tried to retrofit the lows/highs in my 2015 ML350...it's been a nightmare. The bulbs WILL NOT GO IN. Even with the H7 adaptors. No matter what I do, the bulbs simply will not insert into the sockets.
It's hard to see inside the assembly given the nature of the design. These lights are specifically meant for the low beams. When I push the bulb into the assembly, I hear a lot of metal-on-metal noises (when I push and turn the bulb) but nothing "engages". It feels like one metal disk is spinning on another metal disk.
Yes, I'm going through that pain in the *** wheel hatch.
I should mention that I did have the H7 adaptors on this bulb before I took them off - they didn't really stay in place, and I couldn't get the bulb deep enough into the socket with it on for some reason.
I also have LED's from headlight experts.com for the high beams - same exact problem, except with those the H7 adaptor seems to fit more securely on the bulb.
I've tried literally for hours to get these bulbs to properly install, with and without the adaptors. The stock halogen bulbs screw right in, so I am honestly at a loss as to why these damn bulbs just don't work.
Thanks in advance.
Thanks.
Thanks.
http://www.opt-7.com/fluxbeam-led-headlights/#
