ML350 Starts Hard Strange Issue
After having it a few weeks I am having issues starting it up.
When it starts it runs perfectly and does not stall.
The issue is when trying to start it in the morning it will crank over a few times and die. sometimes it will crank 3 times, some time barley once sometimes 4 times then the engine tries to start and it stops cranking and dies.
I have found a bizarre way to get it started consistently. If I do the following procedure it seems to start every time.
1. I try and start the car.
2. Once it stops cranking very quickly turn the key off and back on to try and start it again.
3. If i do it fast enough this second time it will not crank at all, just the tack lights come on but it does nothing, almost as if the electric ignition has not had time to reset yet or something.
4. Once this happens if i then turn the key off an try to start it a third time it will always start.
5. If i just at normal speed turn the key off and on i could do it 10 times in a row and it wont start but this weird method gets it started every time.
Note. when this first started it would only happen when the car sat for a long time like over night and once I got it started and drove it for a bit it would start normally the rest of the day but its been getting worse so now its not starting normally regardless of if ive been driving it.
Any ideas on what might cause this.
I will take a video of this and post it.
Thanks in advance!
Thanks in advance!
